2305 won't start
/ 2305 won't start #1
VABlue
Platinum Member
Thornburg, VA
JD2305
My 2305 has an interlock issue somewhere that won't allow the engine to turnover. It's in neutral, the seat safety switch is bypassed (but I did reconnect it, also, to no affect), and the parking brake is engaged. The engine doesn't even try to start...
This happened after I tried to lift the rear end to add some pressure to the tires (wanted to spin them around so the valve stems were on top). The jack was on the frame that surrounds the PTO, not on the transmission housing. I couldn't get the machine up level to get jack stands under it, it would tilt to one side and I couldn't get it level. After giving up on that, I was going to back it up until the stems were on top, but now it won't start. It did turnover, but conked out because the brake wasn't engaged. I engaged it, but now it doesn't even try...
Any ideas, suggestions, or answers?
/ 2305 won't start
Nevermind... Turns out to be a dead battery. I hooked up the charger in boost mode and got the starter solenoid to engage. Glad it's not an interlock somewhere, but I didn't really expect the battery to die at only 3 years of age... Ahh well...
/ 2305 won't start #3
Do a search...the OEM JD battery's are junk! 99% of the "won't start" threads turn out to be bad battery's.
/ 2305 won't start
Well, they wanted $117 for a green battery, so I put an Exide into it. Started right up!
/ 2305 won't start #5
Glad you figured it out quickly. Amazing to see how many people spend untold hours troubleshooting a no-start, not believing it could possibly be their fairly new battery. Like Kenny said, it usually is the battery, and they usually go very suddenly.
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
PALLET OF AMMO BOXES (A64281)
PALLET OF AMMO...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
