2305 with posthole digger?
/ 2305 with posthole digger? #1
fitzisprint955
Bronze Member
Barneveld. Wisconsin
2305/345GX
Anyone put a posthole digger on the 2305 yet, I see the info with the Backhoe and its seems to be coming along well. I don't think I'll be digging, but the 6.23 might need a new fence in some areas, thanks. Fitz /forums/images/graemlins/wink.gif
/ 2305 with posthole digger? #2
fiz,
deere475_guy used a Speeco unit on his 2210 with a great deal of luck. If you do a search he has some pics of a really clever stand.
/ 2305 with posthole digger? #3
I use a tractor supply Speeco unit on my 2210. Have probably dug 350 to 400 holes without a problem, as soon as warmer weather comes back will be putting another 125 or more posts in for a horse paddock. You only get about 6-7 inches in ground clearance, but that really hasn't been a problem for me. For the price of around $500.00 it’s the best one for the money to go on a 2210/2305.
/ 2305 with posthole digger? #4
Lobo,
thanks for chiming in. I knew someone else had extensive use with the Speeco unit! /forums/images/graemlins/grin.gif
/ 2305 with posthole digger? #5
My brother-in-law uses my PHD on his 4010 which is similar in size to your 2305. When ask, our JD dealer said they did not have one for his tractor. We were wondering why, figuring his 3PH would not lift it high enough. It lifted it high enough to clear the ground (3-4") and that is all that's needed. He's had no problem digging holes in his sand.
/ 2305 with posthole digger? #6
</font><font color="blue" class="small">( My brother-in-law uses my PHD on his 4010 which is similar in size to your 2305. When ask, our JD dealer said they did not have one for his tractor. We were wondering why, figuring his 3PH would not lift it high enough. It lifted it high enough to clear the ground (3-4") and that is all that's needed. He's had no problem digging holes in his sand. )</font>
Is there any way you can give me more information on what PHD he has? I have a 4010 on the way and would love to have a PHD. Any help would be greatly appreciated.
/ 2305 with posthole digger? #7
Mine is an off brand. It is a Green (or Greenline) model 5500 but I am sure the one from TSC would work. Mine was in a package deal with my jd3520. I saw little use for it myself so I'm not sure if it is a heavy duty unit or not.
chuck
/ 2305 with posthole digger? #8
I have the full size PHD and used it on my 2210. About 7" of clearance when lifted. Check out my pic links. I have several pictures of it on the 2210 there. (Speeco from Tractor Supply).
/ 2305 with posthole digger? #9
</font><font color="blue" class="small">( I have the full size PHD and used it on my 2210. About 7" of clearance when lifted. Check out my pic links. I have several pictures of it on the 2210 there. (Speeco from Tractor Supply). )</font>
Thanks for the help. I'm going to look at TSC. JD dealer wants $700 for a PHD. /forums/images/graemlins/shocked.gif
/ 2305 with posthole digger? #10
Your welcome. I believe mine ran $550 out the door with a 12" auger. I have got a little over 300 holes so far and I might think about picking up some new cutting edges in the spring. The rocks at my place tend to dull the cutting edges. Also I think I will be adding a hydraulic down pressure kit to it as soon as I come up with a design.
Good luck.
Bob
/ 2305 with posthole digger? #11
How deep can you go with the auger? Up here in the north, I need to get down at least 42" to get below the frost line.
Thanks /forums/images/graemlins/smile.gif
/ 2305 with posthole digger? #12
The auger I have is 42" and I believe in one of my pics you will see the power head is burried. I live where the frost line is also 42".
250 GALLON FUEL TANK (A64276)
250 GALLON FUEL...
2014 Dodge Journey SUV (A61574)
2014 Dodge Journey...
211298 (A62131)
211298 (A62131)
TAKEUCHI TL12V2 SKID STEER (A65053)
TAKEUCHI TL12V2...
2024 Bobcat T650 (A64126)
2024 Bobcat T650...
Case IH 4200 Combo Mulch (A66285)
Case IH 4200 Combo...
