Buying Advice 2305 rear blade for iMatch
/ 2305 rear blade for iMatch #1
JDforMe
Southern CT
JD 2305
Hi Gang,
I'm looking for a rear blade for my 2305 - mainly for snow removal and some landscaping work. I'm thinking a 6' blade is my best option?
Also wondering if I should just go with the JD / Frontier blade, or if there is another iMatch compatible blade (no adapters or mods required) that offers a more economical or better performing solution. Thanks very much for your opinions and experience!
-Dave
/ 2305 rear blade for iMatch #2
I've got a JD 2210 and picked up a Frontier RB 0560 which was very well built, but then I bought a JD quick hitch. I then found a Frontier 2060 rear blade to fit the quick hitch, only to discover that the king pin and angle pin assembly wasn't nearly as strong as the Land Pride.
Be sure to look at those areas before deciding what to buy. It looks like the better built blades will have the angle pin on the side of the king pin assembly, not on the arm. If you only use a blade for moving snow you might be all right with the lighter built style, but if you will use it to move dirt, get the stronger design and you'll probably be much happier.
In lighter snowfalls a 6' blade may be fine, but if you are trying to move heavier snow you may have to angle a 6' blade quite a bit to get it pushed.
/ 2305 rear blade for iMatch #3
I had a RB1060 when I had my 2210. That was plenty for it in snow. IMO, 6' will be too much. The problem is when angled it will push the rear of the tractor sideways.
/ 2305 rear blade for iMatch #4
I have a 6 foot blade on mine but I also have a 4 foot snowblower on the front clearing a path for it.
Yeah,, I don't see a snowblower in my future.... But it would be nice!
/ 2305 rear blade for iMatch #6
You might want to go with a 5 foot blade then. 6 foot is too much by its self on a 2305. Even with the 5 footer you will need wheel weights, chains and rocks in your pockets.
A five footer it is...... Thanks for the advice.
Still have a question though..... Are JD or Frontier the ONLY implements that are iMatch compatible (without modification) ?
ALSO - any recommendations or suggestions regarding blades that are angle only vs. Angle AND tilt? Tilt seems like a nice feature, but not sure if one is iMatch/2305 compatible... Thanks!
/ 2305 rear blade for iMatch #9
Five footer is the right choice for your machine. If you go with the angle feature and to get the best use out of it you will need hydraulics to operate it. You will be very happy with that choice and versatility. I have a preference to Frontier and they have some great options, but not sure on the five footers.
/ 2305 rear blade for iMatch #10
I tortured myself a bit between 60 and 72 inches. I ended up getting the frontier 60" which has been a perfect size. It covers the tracks fully angled and has a couple nice tilt settings which a easy to use. Even nicer is being able to leave the tilt pin out and float the tilt of the blade, only getting high spots and evening terrain. Even the 60 will push the rear around a bit so I don't doubt at all the 72 could become a pain to manage...This is with a 2305/1026 with filled tires and sometimes some weight in the loader, no chains though. I haven't noticed (as you might expect) any real difference in the ground engagement performance btw the two tractors.
/ 2305 rear blade for iMatch #11
You made a good choice in my opinion and will be happy with it for a long time. Put it to work.
/ 2305 rear blade for iMatch #12
I purchased a 5' rearblade from TSC that is IMatch compatible to use with my x749. You just need to check the fit on any implements you want to buy to make sure they will work for you.
So, I picked up the JD/Frontier RB2060L blade.... Measured a couple TSC models, and tried my brothers 5 footer from northern tool that he runs on his Kubota. No dice on a fit to the iMatch, which is why i went with the Frontier...
Plusses: Its Green, pretty beefy frame for the 5 foot width, iMatch compatible, I didn't have to wait for it, Has already been put to work, and... my dealer is REALLY good.
Minuses: a bit pricey (ok, very pricey), small-ish in height - in comparison to other blades I've come across...
I'll use it a lot.... Not especially strenuous demands...but frequent use. So, I'll see how it works over time...
Thanks!
/ 2305 rear blade for iMatch #14
I had similar issues when shopping for the small boxblade, couldn't find one I liked other than at the dealer. So I wound up with a Cammond 48" boxblade and a Frontier 60" landscape rake. I was able to find the rearblade at TSC for $250 which is good enough for my purposes on a garden tractor. I use these for light touch up work to save me the cost of moving the larger equipment in.
Follow up.... I went with the RB1060 ant think it'll be fine for what I need to do.
Couldn't wait for snow, so I used it to grade a portion of my property along the road that has been neglected. Turned out quite nice - for a rookie!
