rjgogo
Bronze Member
The hydraulics on my 2305 went out and there is a very loud whine in the pump. So far, I have changed the oil and filter in the transaxle, cleaned the mesh filter with the magnets and put it all back together and same problem. After I changed the oil and ran it again to check to see if it was fixed and nothing. The oil in the sight glass was really aerated after running.
I also took the pump off and had a look inside and there does not appear to be any thing in there that would render it non functional but I am no expert. Some very very small scratches on the inside but that is about it.
The whine is very loud and I did run it briefly with the pump off and that confirmed the noise is coming from the pump. I can't seem to find what could be causing this. Any ideas on what I should check next? The tech manual has not been much help but maybe I am looking in the wrong place. Thanks in advance.
