2305 MMM lift
/ 2305 MMM lift #1
woodsleeboy
ontario, canada
Just bought a 2305 tractor today. I got a MMM with the independant lift kit. Does anyone know if this works off the joystick or not? Is it a good choice as opposed to the mech. lift? I still have time to change the lift if the mech. lift is better
/ 2305 MMM lift #2
I am getting close to buying a Deere 2305 with the MMM independent lift and am also interested to see if anyone can offer comments compared to the mechanical version. /forums/images/graemlins/grin.gif
/ 2305 MMM lift #3
woodsleeboy,
You are probably getting one of the first MMM lift kits, so we're not positive how it works, but another poster did this with his 2520, and it required one of the spools on the SCV joystick. This disadvantage of this, is, if you want to use the loader while the deck is on the tractor, although there may still be a way to lock the deck up in transport mode. If you don't get this kit, the way the MMM works is off of the 3PH there is a fab'd bracket that raises and lowers the deck off of the lower link arms. The disadvantage/pain about this, is that it requires a spreader bar between the link arms to keep them apart. /forums/images/graemlins/tongue.gif
/ 2305 MMM lift #4
I have the 2305 with indep. mmm lift. I haven't used it with the deck yet, but it does use one of the existing ports, so you have to unplug one of your loader hoses (just one as it is gravity down) to use it. If you need the loader, just raise the mmm, lock it in the up position with the depth control knob, then unplug the coupler and plug in the one loader hose thats left.
