2305 hydrological hookup issues
/ 2305 hydrological hookup issues #1
mwark
Maine
L6060
My mother has a 2305 and being the good son that I am I switch the blower over to the loader and mowing deck for her every year.
What is the deal with the back presser on these hookups? These things are unbelievable. The manual says to move the control arm around to relieve the presser but that didn't help in the least.
I'm a Kubota guy and I don't have any issues with my hookups. Do you guys have some trick that might help me out here? I was covered with fluid and nearly tore out my rotator-cuff.
Thanks, Mike
/ 2305 hydrological hookup issues #2
It's a common problem (with Kubota's also-you've been lucky). The pressure is on the implement side-the easiest way to relieve it is to wrap a rag over the QD nipple and press it against the frame to push the poppet in-a little fluid will spurt out relieving the pressure. In extreme cases two wrenches must be used to loosen the QD from the hose for a second.
It happens often when stuff sets in the sun and the fluid heats up and expands.
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thank you.
/ 2305 hydrological hookup issues #4
I have the same issue with my Kubota FEL, except it is always just the one hose and the weird part it will connect to every other fitting but the one it is supposed to do. Bleeding it off always does the trick like said in an earlier post.
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2006 Ford E-450 (A64119)
2006 Ford E-450...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
