2305 hydrological hookup issues
/ 2305 hydrological hookup issues #1
mwark
Bronze Member
Maine
L6060
My mother has a 2305 and being the good son that I am I switch the blower over to the loader and mowing deck for her every year.
What is the deal with the back presser on these hookups? These things are unbelievable. The manual says to move the control arm around to relieve the presser but that didn't help in the least.
I'm a Kubota guy and I don't have any issues with my hookups. Do you guys have some trick that might help me out here? I was covered with fluid and nearly tore out my rotator-cuff.
Thanks, Mike
/ 2305 hydrological hookup issues #2
It's a common problem (with Kubota's also-you've been lucky). The pressure is on the implement side-the easiest way to relieve it is to wrap a rag over the QD nipple and press it against the frame to push the poppet in-a little fluid will spurt out relieving the pressure. In extreme cases two wrenches must be used to loosen the QD from the hose for a second.
It happens often when stuff sets in the sun and the fluid heats up and expands.
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thank you.
/ 2305 hydrological hookup issues #4
I have the same issue with my Kubota FEL, except it is always just the one hose and the weird part it will connect to every other fitting but the one it is supposed to do. Bleeding it off always does the trick like said in an earlier post.
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
2022 EZ-GO ELITE...
RAIN FLOW HOLE PUNCH, 3PT (A63291)
RAIN FLOW HOLE...
FAST CRAFT FIBERGLASS BOAT (A63291)
FAST CRAFT...
2026 Electric Tricycle (A64194)
2026 Electric...
2019 Polaris Ranger Crew XP1000 4x4 Utility Cart (A61572)
2019 Polaris...
