2305 hydrolic oil question
   / 2305 hydrolic oil question #1
impnst8
Tewksbury Twsp., NJ
JD 2305
I have a new 2305, and found that the oil in the rear sight glass is low. I check this as I was attempting to back-blade a dirt pile and found that I had no downward pressure. Anyway, I checked the owner's manual and was a little confused. Is the oil sight glass and filler plug the same for the transmission and the hydraulics??? And if so, do I have to buy JD fluid? If I were to go to Walmart or PepBoys, what type of fluid do I need to buy? My JD dealer is not that close and their hours and my hours never match. Thanks.
   / 2305 hydrolic oil question #3
I know some people on here wouldn't use anything but John Deere oil. But you can use any brand as long as it meets J20D or J20C standards. They will tell you on the container. I'm not sure which on is for cold weather, and the other is for places where it don't get so cold. I think the D is for where it is cold, maybe someone else will get on here and tell you.
   / 2305 hydrolic oil question #4
   / 2305 hydrolic oil question #5
Are you talking about using a box blade on the rear? If so, the only down pressure you will have is the weight of the box blade. Also, auto-parts stores will carry hydraulic fluid. JC
   / 2305 hydrolic oil question #6
   / 2305 hydrolic oil question #7
I second that there is no down pressure on your 3PH. The weight of the implement is the down pressure. /forums/images/graemlins/tongue.gif
   / 2305 hydrolic oil question #8
   / 2305 hydrolic oil question #9
Check the sight glass with all pressure off the machine, i.e., lower the three point all the way down, return to neutral position, and allow the loader to rest on the ground and check it when the machine is cold.
   / 2305 hydrolic oil question #10
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
Deere 9965 Cotton Picker (A52128)
Deere 9965 Cotton...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
2012 Audi Q7 (A50324)
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
Kraus Drive Over Fertilizer Conveyor (A50514)
Kraus Drive Over...
