2305 hydrolic oil question
/ 2305 hydrolic oil question #1
impnst8
Tewksbury Twsp., NJ
JD 2305
I have a new 2305, and found that the oil in the rear sight glass is low. I check this as I was attempting to back-blade a dirt pile and found that I had no downward pressure. Anyway, I checked the owner's manual and was a little confused. Is the oil sight glass and filler plug the same for the transmission and the hydraulics??? And if so, do I have to buy JD fluid? If I were to go to Walmart or PepBoys, what type of fluid do I need to buy? My JD dealer is not that close and their hours and my hours never match. Thanks.
/ 2305 hydrolic oil question #3
I know some people on here wouldn't use anything but John Deere oil. But you can use any brand as long as it meets J20D or J20C standards. They will tell you on the container. I'm not sure which on is for cold weather, and the other is for places where it don't get so cold. I think the D is for where it is cold, maybe someone else will get on here and tell you.
/ 2305 hydrolic oil question #4
/ 2305 hydrolic oil question #5
Are you talking about using a box blade on the rear? If so, the only down pressure you will have is the weight of the box blade. Also, auto-parts stores will carry hydraulic fluid. JC
/ 2305 hydrolic oil question #6
/ 2305 hydrolic oil question #7
I second that there is no down pressure on your 3PH. The weight of the implement is the down pressure. /forums/images/graemlins/tongue.gif
/ 2305 hydrolic oil question #8
/ 2305 hydrolic oil question #9
Check the sight glass with all pressure off the machine, i.e., lower the three point all the way down, return to neutral position, and allow the loader to rest on the ground and check it when the machine is cold.
/ 2305 hydrolic oil question #10
Actually, I was using the FEL. I had no downward pressure on the bucket itself. That prompted me to stop work and check the sight glass. Is there only one oil filler for the transmission and the hydraulics on the 2305?
/ 2305 hydrolic oil question #13
</font><font color="blue" class="small">( Actually, I was using the FEL. I had no downward pressure on the bucket itself. That prompted me to stop work and check the sight glass. Is there only one oil filler for the transmission and the hydraulics on the 2305? )</font>
Correct, the fill cap is next to the seat and you need to make sure all the attatchments are on the ground and the engine is off. The site window should be half to three quarters full in that position. I found out mine was low due to the fact the dealer didn't check it after adding the loader. I did find a brand at my local parts place that is referenced to JD.
/ 2305 hydrolic oil question #14
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
2004 Isuzu NPR 14ft. Box Truck (A61573)
2004 Isuzu NPR...
2016 Ford Taurus Sedan (A61574)
2016 Ford Taurus...
2018 RoGator 1100C (A63688)
2018 RoGator 1100C...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
