2305 for hay ride use ?
   / 2305 for hay ride use ? #31
The BX don't have Brakes per say.
They have a brake pedal which when stomped upon while moving locks up both rear tires, [sarcasm] perhaps it would be more semantically correct to say that they have a brake pedal which applies resistance to the driven tires (inasmuch as the differentials allow)[/sarcasm]
Aaron Z
   / 2305 for hay ride use ? #32
Aaron Z
This is entirely different than Brakes as we know them in the automitve field.
Do you rely on your cars emergency brake petal or lever to stop every time you want to?
   / 2305 for hay ride use ? #33
What are you talking about? The brakes in our BX2660 or L3830 do the same thing as the ones on a car, the friction material is pushed against the metal disc and the tractor stops. The differences between the BX2660 or L3830 brake system and a automotive brake system are: wet vs dry brakes, mechanical vs power assisted brakes and (in the L) split rear vs 4 wheel brakes.
According to the exploded parts diaghram on the Messicks site the BX2660 appears to have a "standard" (for a tractor) design of wet disc brakes to see it and compare it to the brakes on a L3830 go to Kubota BX2660D Parts Diagrams, look up "BRAKE" under "BRAKE' for the BX2660. The brakes are item 60.
To see the same on a L3830GST go to Kubota L3830DT/GST/HST Parts Diagrams, choose "BRAKE LH [GST TYPE]" from under "REAR AXLE/BRAKE". The brakes are items 180, 190 and 180.
They are similar in design to those on the BX2660, the difference is that the BX has a single brake and the L has split brakes.
Aaron Z
2012 JOHN DEERE 160G LC EXCAVATOR (A52705)
2012 JOHN DEERE...
(2) SQUIRREL CAGE FANS (A54757)
(2) SQUIRREL CAGE...
2015 Ford F-250 Knapheide Service Truck (A55788)
2015 Ford F-250...
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
40' CONTAINER (A51244)
