2305 for hay ride use ?
   / 2305 for hay ride use ? #31
The BX don't have Brakes per say.
They have a brake pedal which when stomped upon while moving locks up both rear tires, [sarcasm] perhaps it would be more semantically correct to say that they have a brake pedal which applies resistance to the driven tires (inasmuch as the differentials allow)[/sarcasm]
Aaron Z
   / 2305 for hay ride use ? #32
Aaron Z
This is entirely different than Brakes as we know them in the automitve field.
Do you rely on your cars emergency brake petal or lever to stop every time you want to?
   / 2305 for hay ride use ? #33
What are you talking about? The brakes in our BX2660 or L3830 do the same thing as the ones on a car, the friction material is pushed against the metal disc and the tractor stops. The differences between the BX2660 or L3830 brake system and a automotive brake system are: wet vs dry brakes, mechanical vs power assisted brakes and (in the L) split rear vs 4 wheel brakes.
According to the exploded parts diaghram on the Messicks site the BX2660 appears to have a "standard" (for a tractor) design of wet disc brakes to see it and compare it to the brakes on a L3830 go to Kubota BX2660D Parts Diagrams, look up "BRAKE" under "BRAKE' for the BX2660. The brakes are item 60.
To see the same on a L3830GST go to Kubota L3830DT/GST/HST Parts Diagrams, choose "BRAKE LH [GST TYPE]" from under "REAR AXLE/BRAKE". The brakes are items 180, 190 and 180.
They are similar in design to those on the BX2660, the difference is that the BX has a single brake and the L has split brakes.
Aaron Z
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
UNUSED RAYTREE RMT48 HYD TRENCHER (A54757)
UNUSED RAYTREE...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 KZ Sportsman...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A55787)
2025 GIYI Stump...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
Miller Bobcat 250 Diesel Welder (A54865)
Miller Bobcat 250...
