2305, 54" MMM
/ 2305, 54" MMM #1
ChrsDrn
Auburn NH
Hi,
I got my 2305 last fall I used it 2X to moe my lawn... loved it, but on the first day I hit a stump with a blade and stalled the engine. ouch, I saw the stump and thought it would clear... anyhow it restarted fine and I finished mowing that day and the next time no problem... then I bought the mulching kit and installed it. the blades were hitting each other... apperently the mower deck and my old blades were bent... I am surprised that there is no shear pin in this system, I am not sure it would have helped. My dealer quoted me a price of $1100 to replace the mower deck pan, I think this is like 95% of the price I paid for it... they also said the can try to straighten it for $200... becareful of the stumps i guess.
Chris
/ 2305, 54" MMM #2
Ouch...!! :( That's a pretty expensive stump! One concern that I would have with your dealer straightening the deck - make sure the pulleys are all tracking straight and in alignment with each other.
Or you might find that you've got a belt "eating monster" on your hands! (And the shaft bearings might have a shortened lifespan, too.)
For the cost - I'd definitely try the repaired deck before the replacement deck.
Or look around for a good used deck..
Good luck.
AKfish
/ 2305, 54" MMM #3
Hi ChrsDrn ,
That's a bad day ... How big was this stump ??? - Ht./Dia.
A shear bolt would be used in a direct drive system like a snow blower , but
the mower deck has the belt to give or slip IMO , I'm surprised it did all that
damage , especially shutting down the tractor , learn something everyday ...
I'll furshur be watching for those stumps ...
Later,x595
/ 2305, 54" MMM #4
/ 2305, 54" MMM
Got it back today it seems to running well, my lawn is still too short to mow time will tell. going to rent a stump grinder and kill that stump... it is about a foot in diameter and < 1/2 inch tall.
thanks for the info
Chris
/ 2305, 54" MMM #6
Been there, stalled the engine hitting something that is. I think I once got a rock caught under the deck and stalled the motor. No damage except a gouge in the blade, don't think I was running the motor full speed at the time. There were a couple times something got stuck under the PTO rear roto tiller and stalled the motor. There is a slip clutch on the tiller but I don't know why it didn't slip. First time was a 3/8"x 10' steel rod that was hiding and it wrapped several times around the tines before the motor on the 2210 stalled. that was fun cutting that out with a hacksaw!
AGRIC AFMJ65 - 65" ROTARY TILLER (A64277)
AGRIC AFMJ65 - 65"...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
Ditch Witch Mixing System FM13V (A65579)
Ditch Witch Mixing...
Man Basket (A65640)
Man Basket (A65640)
