2305 3PH question
/ 2305 3PH question #1
netwayne
Tar Heels Baby!
I was putting the mmm back on the tractor today and noticed that the left 3ph arm that has the plate above it that is responsible for lifting the mmm is barely under that plate. I have adjusted the 3ph left arm out (now there's considerable play) to be able to get under that plate but because of the play, it barely catches the plate when lifting. This may be normal but doesn't look quite right. Was curious if others have this "issue" as well.
Thanks!
/ 2305 3PH question #2
Wayne,
you should have received a spreader bar to go inbetween
your lower 3ph links, that keeps the arms spread where they
need to be to maintain contact with that lift bracket. then,
like normal with any other 3ph implement, adjust your sway
like usual.. that should be all you need.
let us know if not
:D
/ 2305 3PH question
Wayne,
let us know if not
:D
Yes, I had forgotten to put that back on when changing implements (rookie mistake). You are exactly right! Thanks Dutch!
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2009 FORD E-150 CARGO VAN (A66091)
2009 FORD E-150...
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
2007 Freightliner M2 106 Pothole Patcher Truck (A66736)
2007 Freightliner...
500 GAL WATER TANK (A68842)
500 GAL WATER TANK...
