22MM Pressure Washer Fitting,, Need Help Finding
/ 22MM Pressure Washer Fitting,, Need Help Finding #1
CADplans
Elite Member
near Roanoke VA
584 IH 4WD
I purchased a wheeled, deck cleaning attachment, and a 12 foot extendable wand,, in hopes that I could pressure wash a metal roof before painting.
The hope is that I can pressure wash without being on the roof,, I don't trust myself with a 4,000 psi pressure washer,, while standing on the roof.
The problem: both the wheeled deck, and the wand have identical 22MM threads, I have not been able to find a union fitting.
The threads on both items look like this,,,
So, the fitting I need is the opposite of the fitting in the pic above.
Everybody sells the pictured fitting,, but, the opposite fitting seems to be eluding me,,,
Am I looking for a unicorn??
/ 22MM Pressure Washer Fitting,, Need Help Finding #2
pretty much yes, a unicorn.
Really the only options are to make an adapter by putting 2 readily-available adapters together
I did see the NPT-M adapter, then went looking and found the 3/8 NPT-F adapter,, so I ordered both,,,
I hope that works,, am not familiar with this 4,000 psi water stuff,,, :confused2:
/ 22MM Pressure Washer Fitting,, Need Help Finding #4
Good source of pressure washer parts is Water Cannon
/ 22MM Pressure Washer Fitting,, Need Help Finding #5
Almost looks like 3/4 11.5 garden hose thread.....
Yea, it is a weird fitting, the threads hold it together, but, it O-ring seals inside the fitting,,
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
Wilbeck 2109 12ft. Digger Disc Chisel (A65640)
Wilbeck 2109 12ft...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
(1) 30 Yard Roll Off Dumpster and (1) 20 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
