2240 Hydraulics bleeding off
/ 2240 Hydraulics bleeding off #1
THEPARTYHOUND
Montana
JD 2240 MFWA (SOLD); Kioti RX7320
The hydraulics on my tractor bleed off over a short period of time. If i lift a bucket of dirt, it will drop 3 inches a minute, or more. Same on the curl, same on the 3 point. How hard is that to fix and what would it entail?
/ 2240 Hydraulics bleeding off #2
3 pt & loader boom/bucket cylinders leaking down although both are hydraulic they are not related. 3 pt problem could be leaking control valve from faulty seals or set too tight &/or faulty rockshaft piston seal. Repair of either requires R&R of rockshaft housing from tractor. RS valve clearance can be changed by removing a plug on RH side of RS housing then turning a screw. Loader boom settling is caused by worn control valve & repair requires valve replacement. Settling of bucket could be failed bucket cyl piston packings on 1 or both cylinders or worn out control valve
The control valves shouldnt be too costly to replace?
/ 2240 Hydraulics bleeding off #4
Do you have quick disconnects on the hoses from the valve to your loader?
If so, you could disconnect the hoses and see if the dropping stops. If it does, the valve is leaking. If it continues to drop, the cylinders are leaking internally. Be for warned disconnecting the hoses might be hard to reconnect, due to the pressure trapped in the lines.
The valve will be very expensive.
/ 2240 Hydraulics bleeding off #5
Zebrafive
I have a question. Maybe I can't see the forest for the trees because I'm getting OLD!!!!!!
If 1 or both frt end loader boom cylinders are leaking at piston seals then for ""boom to lower"" piston must move in cyl barrel toward butt of cyl end therefore displacing a larger volume of oil into rod end of cyl barrel because rod occupies some of the area where does this oil go if rod seal is good & control valve isn't leaking internally IE how can boom lower???
Thanks,Jim
/ 2240 Hydraulics bleeding off #6
Zebrafive
Thanks,Jim
I see what you are say Tx Jim, I can't explain it. I am guessing the same way a shock absorber works, the oil somehow goes from the "butt" end to the rod end. I am thinking is the cylinder piston seals are shot, the oil can and will leak by.
/ 2240 Hydraulics bleeding off #7
Just food for thought:
Referring to shock absorber the shaft is much smaller in size in relation to barrel size than a normal hyd cylinder. Boom barrel ID on JD 145 FEL is 2'' while rod OD is 1.48'' which doesn't leave a lot of room for the extra amount of oil that must enter rod end of cyl barrel if piston seal is leaking.
I think if FEL boom cyl piston seal is leaking cyl will hydraulically lock before piston moves very far into barrel if control valve isn't leaking internally.
No quick disconnects on valve; the hoses thread in. The cylinders do leak a bit around the shaft, but it is really just a slight seepage. Is there a way to tell for sure if the cylinder is leaking internally? There is a guy locally that rebuilds cylinders, but not valves to the best of my knowledge. Guess i could ask him...
/ 2240 Hydraulics bleeding off #9
You can disconnect hose from end of cylinder that piston has fully traveled,leave orifice open,apply hyd pressure to other end of cyl & if piston packing(seal) has failed oil will exit open orifice.
Ok, that makes sense. Do i need to have the cylinder fully extended to do this? Theres not going to be a lot of pressure on the hose when i take it off is there?
/ 2240 Hydraulics bleeding off #11
Fully extended or retracted is fine but the direction determines which hose needs to be removed.
/ 2240 Hydraulics bleeding off #12
Sounds like a better way of texting the cylinder.
/ 2240 Hydraulics bleeding off #13
This is the easiest to understand double acting cylinder test I have seen.
Dave M7040
Awesome dave, that does spell it out very clearly!
/ 2240 Hydraulics bleeding off #16
I agree Dave's post is very helpful.
/ 2240 Hydraulics bleeding off #17
Dave M7040
May I ask you what your opinion is if a failed FEL boom cylinder piston packing will or will not allow the boom to settle if hyd valve isn't leaking?
Thanks,Jim
Transfer tank (A61567)
2008 Bush Hog 3715 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
2008 Bush Hog 3715...
2024 DODGE RAM 2500 HEAVY DUTY PICKUP TRUCK 4x4 (A59912)
2024 DODGE RAM...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2010 Scag STT52V-27CH 52in Zero Turn Mower (A61572)
2010 Scag...
UNUSED WOLVERINE HYD STUMP GRINDER (A64281)
UNUSED WOLVERINE...
