224 Tach problem
/ 224 Tach problem #1
TSMART
central florida
jinma jm 224
Cold start, no tach. Comes on after an hour, florida climate. I removed fuses, cleaned and replace. Same thing happens repeatedly, all other gages fine. Im stumped.
/ 224 Tach problem #2
I believe the tach has a sensor up by the flywheel. Probably just a bad chinese part.
Steve
/ 224 Tach problem #3
Might be just bad setting on the sensor. Back off the sensor. Gently screw it back in till it just touches the flywheel, then back it off, I believe about a 1/2 turn. Try that.
Dave
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2015 FREIGHTLINER...
1996 International 4700 (A64127)
1996 International...
Unused 2023 Monroe Tufline TW92420 9ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
MI-T-M HDS-3005-Z004 PORTABLE PRESSURE WASHER (A65054)
MI-T-M...
2011 HUTCHISON CRUDE TRAILER (A67714)
2011 HUTCHISON...
