223D Starting issues
/ 223D Starting issues #1
T Rice
My tractor has had trouble starting lately.
The ignition switch is making but nothing gets to the starter.
If I cross the starter lead posts with a screwdriver a few times it tries to turn the started but doesn't seem to engage the flywheel gear. Then after I do this a few times then she'll start with the key once.
Shut her down and I have to go thru this routine again.
I'm guessing the solenoid is going south.
Any opinions?
Thanks
TR
Any other ideas? Key switch maybe? I guess I can check that with a meter.
I just installed a new solenoid and have the same problem. Even when I jumper between the posts it takes a few times before the solenoid kicks in. Every time the first few hits turns the starter motor over but it's not engaging the flywheel.
BTW what's supposed to go on the spade terminal on the solenoid between the main power posts? Mine never had anything connected there for as long as I've had it.
I guess I'll be carrying around my "starting hammer" for a bit longer.
/ 223D Starting issues #4
Check your ground. I was ready to buy a new starter when I found the ground bolt on the fram had become loose.
Just bringing this one back to the top.
Nobody knows what that spade connector on the soleniod is for?
/ 223D Starting issues #6
check all your connections.If your connections are good. Put a volt meter on the batt. when trying to start & watch the voltage
Sunflower Yard Art (A64557)
Sunflower Yard Art...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2012 FORD FOCUS SEL (A65054)
2012 FORD FOCUS...
1996 Ford F-350 Pickup Truck (A64194)
1996 Ford F-350...
2019 HYDREMA MX18 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX18...
2026 Electric Tricycle (A64194)
2026 Electric...
