2210 Skid Plate
/ 2210 Skid Plate #1
David_B
New Jersey
John Deere 2210
Hi guys,
Does anyone make a skid plate or some type of protection bracket to protect the hydraulic filter on a 2210? I have quite a few rocks on my property & I'm afraid of not seeing one under the leaves, etc. and beating up that filter - or worse. /forums/images/graemlins/shocked.gif
Thanks for the help.
David B
You know, a folding ROPS would be really nice too.....
/ 2210 Skid Plate #2
If your doing any brush cutting or just going over heavy brush you have more to be concerened with than just the oil filter. Your hydro cooling fan is down there exposed also. Mine was getting pretty gouged up when I traded it in. I think there have been a few that actually broke theirs. Dealer says it's not a cheap repair and not covered under warranty so beware. Also the only time I dented my hydro oil filter is when I was taking my mower deck off and pulled it from under the tractor after I had rolled the tractor forward just a little to clear the front wheels.
/ 2210 Skid Plate #3
i was under my 2210 the other day and looking at the exposed fan. im thinking of making a cage type of gaurd for it and posibley a gaurd for the hyrdo filter. on my 455 the filter is in the same place but lower to the ground and every time i have changed the filter it has be dented pretty bad. strange.. i have never drove my 455 on any signifigently rough areas i think the deck may hit it some how.?
/ 2210 Skid Plate #4
Hi,
I think I am quoting the right numbers here but JD has so many that I get a little confused.
J
ust for future reference, does the 2305 have the same issues re fans and filters\possible damage as the 2210 or did they move them around so there is less chance of damage.
Tom
/ 2210 Skid Plate #5
</font><font color="blue" class="small">( Hi,
J
Tom
)</font>
I got a new 2305 just this week, and after reading a few of the posts here, decided I better have a look. There is a skid plate factory installed under the fan which looks to be sufficient. Anyone had any issues with the 2305 and the hydro fan, or think that more is needed??
/ 2210 Skid Plate #7
</font><font color="blue" class="small">( There is a skid plate factory installed under the fan which looks to be sufficient. Anyone had any issues with the 2305 and the hydro fan, or think that more is needed??)</font>
<font color="green">Curiously enough when I went to jdparts.deere.com I couldn't find an illustration of this plate on the 2305 so I could compare it to the one on the 2210 with which I am familiar. The plate under the fan on the 2210 certainly helps but not to the extent some of us need.
See key number 17 in this link for the plate that goes under the fan on a 2210.
Mike </font>
/ 2210 Skid Plate #8
</font><font color="blue" class="small">( Would you be able to take a picture of the skid plate and post?
Thanks )</font>
I'll try shortly.
/ 2210 Skid Plate #9
Trying to post photos for first time. I have 9 pics .
/ 2210 Skid Plate #13
<font color="green">Thanks for posting the great pictures! Looks pretty much like the protection for the hydrostatic cooling fan on a 2305 is pretty much the same as it is on a 2210.
Be careful around trees where there are sticks on the ground. Looks like the same issues exist for the 2305 as the 2210 so far as the possibility of destroying the fan is concerned.
Mike </font>
/ 2210 Skid Plate #14
I thought the guard for the 2305 was the fix from the 2210's problem. I never looked at a 2210. I assumed from the way everyone talked that there was no guard.
This gives me something else to worry about /forums/images/graemlins/confused.gif
/ 2210 Skid Plate #15
</font><font color="blue" class="small">( I thought the guard for the 2305 was the fix from the 2210's problem. I never looked at a 2210. I assumed from the way everyone talked that there was no guard.
This gives me something else to worry about /forums/images/graemlins/confused.gif )</font>
ditto! /forums/images/graemlins/mad.gif
