2210 MMM Questions
/ 2210 MMM Questions #1
anojones
WA
JD 3320
Hello- I'm looking at a 2210 with FEL, a rotary mower and perhaps a box blade. Initially we will use the 2210 for some land preparation around our new place- putting in a lawn, moving some dirt, some minor driveway grading etc. We would eventually be using it as a finish mower around the house and to rotary mow some fields. My quesiton is- how much does the MMM get in the way or other chores, and is the MMM easy to take on and off? Thanks.
/ 2210 MMM Questions #2
Like most MMM'ers, it does get in the way of some of those heavier chores. The 2210 MMM is VERY easy to remove. I wish my 4110 MMM was that easy, even though it's not too bad.
/ 2210 MMM Questions #3
I have not had a problem with the mower getting in the way. I have done loader work, used a tiller & landscape rake & also used a front mount grader blade with the MMM attached.
These were all quick jobs & the mower did not have any effect on how I completed the work. If I were going to do alot of work I would remove the mower. The mower is very easy to remove.
/ 2210 MMM Questions #4
Ditto the above posts. The mower really doesn't get in the way, and if it does, it is really easy to remove.
/ 2210 MMM Questions #5
Just a side comment: I err on the side of removing my MMM if I think there is any possibility that I will catch the deck on something or drive a corner into the dirt. The extra five minutes of precaution is a small cost compared to having to straighten or replace components of the deck lift and suspension assembly. Yes, I gained this philosophy from experience /forums/images/graemlins/blush.gif
Thanks to all- the dealer initally told me the MMM would be difficult to remove. Clearly, not the case.
A Jones
/ 2210 MMM Questions #8
Just a side comment - You'll LOVE the cutting action of that MMM! It gives me one very nice looking lawn - Get a lot of nice comments. Just keep the underneath cleaned out (I scrape it every 3 or 4 cuttings) and those 3 blades sharp. It'l do a great job for you!
Andy
208316 (A58375)
208316 (A58375)
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
