2210 implements
/ 2210 implements #1
shager
What size bush hog and disc should i use with my 2210 tractor?
Also i have a 5 ft yanmar tiller that sometimes when i am using causes my tractor to run hot am i overworking it, to fast or do you think there may be another problem. It takes about 20 minutes of tillibng in red clay to get too hot.
thanks steve
/forums/images/graemlins/smile.gif
/ 2210 implements #2
Shager,
IMO: Your tractor should be very capable of handling just about any 5' implement. I suspect you may have a cooling problem or perhaps too much anti freeze? What gear are you using the tiller in, and what speed is the PTO set at?
Regards, Mark
/ 2210 implements
Mark,
the 2210 has so many gears to choose from, i'm pretty slow but i do have almost a pure mixture of antifreze in the radiator. guess i should add some h20. what is best mixture?
Steve
/ 2210 implements
also where is the pto adjustment? where is best place to get an ENGLISH manual?
/ 2210 implements #5
First thing...Drain the radiator and use a 70% water 30% Anti Freeze mixture. If your exposed to extreme cold than a block heater, oil radiated heater and blanket, our another source of outside heat is preferable to excess anti freeze.
A manual is available from many dealer-members right here on TBN. A general location added to your profile will help you considerably.
As for selecting the correct PTO gear and RPM for your model, I am sure someone will chime in with what works best.
Mark
/ 2210 implements #7
You need to go to a 50/50 mix on your anti-freeze. Any more and it won't cool as good. If that doesn't do it, then the tiller is to big for your tractor, given that type of soil. BTW, JD recommends a 48".
2008 UNKONW  SPOOL TRAILER (A63569)
2008 UNKONW SPOOL...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
207275 (A52708)
207275 (A52708)
Hydraulic Auger Bits (A61572)
Hydraulic Auger...
