2210 implements
/ 2210 implements #1
shager
What size bush hog and disc should i use with my 2210 tractor?
Also i have a 5 ft yanmar tiller that sometimes when i am using causes my tractor to run hot am i overworking it, to fast or do you think there may be another problem. It takes about 20 minutes of tillibng in red clay to get too hot.
thanks steve
/forums/images/graemlins/smile.gif
/ 2210 implements #2
Shager,
IMO: Your tractor should be very capable of handling just about any 5' implement. I suspect you may have a cooling problem or perhaps too much anti freeze? What gear are you using the tiller in, and what speed is the PTO set at?
Regards, Mark
/ 2210 implements
Mark,
the 2210 has so many gears to choose from, i'm pretty slow but i do have almost a pure mixture of antifreze in the radiator. guess i should add some h20. what is best mixture?
Steve
/ 2210 implements
also where is the pto adjustment? where is best place to get an ENGLISH manual?
/ 2210 implements #5
First thing...Drain the radiator and use a 70% water 30% Anti Freeze mixture. If your exposed to extreme cold than a block heater, oil radiated heater and blanket, our another source of outside heat is preferable to excess anti freeze.
A manual is available from many dealer-members right here on TBN. A general location added to your profile will help you considerably.
As for selecting the correct PTO gear and RPM for your model, I am sure someone will chime in with what works best.
Mark
/ 2210 implements #7
You need to go to a 50/50 mix on your anti-freeze. Any more and it won't cool as good. If that doesn't do it, then the tiller is to big for your tractor, given that type of soil. BTW, JD recommends a 48".
2007 KENWORTH T800 MID-ROOF SLEEPER (A63569)
2007 KENWORTH T800...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63118)
2019 Cadillac XTS...
2018 RoGator 1100C (A63118)
2018 RoGator 1100C...
1974 Ohio Body Dry Van Trailer (A64047)
1974 Ohio Body Dry...
