2210 front axle
/ 2210 front axle #1
DJLX
East TN
JD 2210
I have noticed recently more noise or maybe a vibration when engaging the front axle. Last night I raised the front end off the ground with the loader, turned off the engine and rotated one of the wheels (MFWD disengaged). There is some gear noise/ vibration but don't have anything to compare with so don't know if it is abnormal. Oil level is good. Anyone else experience this?
/ 2210 front axle #2
I always thought the front axle on my 2210 was loud. I never had another one to compare.
D.
/ 2210 front axle #3
I have been pumping grease into that thing ad nauseum because of the whine.There is also a difference when Im in 4wd.
/ 2210 front axle #4
The only real noise my 2210 makes with MFWD engaged is when I forget and drive on dry pavement or something like that. Maybe you should change your lubricant. /forums/images/graemlins/tongue.gif
/ 2210 front axle #5
I noticed that my neighbors 2210 has a serious front axle problem; that is, the left front wheel when engaged and underload, i.e., pulling something is skipping/grabbing and a good old crunching noise. The dealer is picking it up today and I will post the results later.
3PC. GALVANIZED HAY RING W/ (1) EXTRA PIECE (A62130)
3PC. GALVANIZED...
2015 Caterpillar 303.5E2 Midi Excavator (A61567)
2015 Caterpillar...
New/Unused Landhonor 20,000lb Electric Winch (A61166)
New/Unused...
UNUSED WOLVERINE TR-26-01C 3PT QUICK HITCH (A62131)
UNUSED WOLVERINE...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
Pallet of Chain Slings (A61166)
Pallet of Chain...
