2210 FEL - Float Mode - does it have it?
/ 2210 FEL - Float Mode - does it have it? #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
2210 FEL - Float Mode - does it have it? If so, how do I engage it?
D.
/ 2210 FEL - Float Mode - does it have it? #2
Push the joy stick forward past the detent. Did your dealer provide an owners manual? It's covered in there.
-Dan
/ 2210 FEL - Float Mode - does it have it? #3
DHennet is correct.
When these are new, you have to really "shove" the stick forward to get it into float - it will loosen up after a bit.
/ 2210 FEL - Float Mode - does it have it? #4
I've asked this question about the float on my 4010. Yes, the owner's manuals tells about it but doesn't really tell you what to do to get there.
You just jam the joy stick full forward. You'll feel it go into a detent that is float. You can still do the curl (side to side on joy stick) with it in float.
Sort of the same way for the 3 pt. It will float above any position that you move it to; you should be able to lift the arms by hand if they're not all the way to the top. With it all the way down and lever left there, the arms will float up from there..
Ralph
Yeah, I got the manual and I did read it but It was picking the front end off the ground...I must not have pushed it hard enough... I will check it out again. I figured if I pushed it any harder, the **** thing would come off in my hand.
Thanks,
D.
/ 2210 FEL - Float Mode - does it have it? #6
<font color="green">I find with my 2210 if you give the joystick a really quick push all the way forward past the detent the loader doesn't have time to lift the front of the tractor off the ground before it goes into float.
Mike </font>
/ 2210 FEL - Float Mode - does it have it? #7
I'm glad to hear I wasn't the only goof when it comes to the FEL float. Just be bold and quickly jam the stick forward. You'll feel it go into the detent. Pretty soon, you'll get good at it and can easily make it go into float even before the bucket hills the ground.
Float's good for going backwards to level out piles you've dumped. It's also good for snow blading when level and going forwards.
Ralph
Way cool - I tried it out tonight.
Thanks,
D.
