2130 JD oil out of the top of the steering column
   / 2130 JD oil out of the top of the steering column #1
lpoworski
2130 John Deere
Hello, we have a 2130 JD that, while driving, started leaking a large amount of oil out the top. We watched Bundy Bears Shed video which was very informative. If anyone has done this job on the tractor we are at the stage where the big nut is loosened but we can't turn the steering wheel any further than its normal limit to get it to release. Anyone run into this? Would appreciate any advice. Thx
   / 2130 JD oil out of the top of the steering column #2
So much for Bundy Bear. Get yourself a proper manual. You need to take a few things apart down below before the shaft and control valves will come out the top.
Thank you. Maybe I’m explaining wrong. I’m not trying to remove the whole column, just the inside to change the 6 orings.
   / 2130 JD oil out of the top of the steering column #4
   / 2130 JD oil out of the top of the steering column #5
In order to access the 6 large o-rings(L34451) one needs to remove steering wheel cap & steering wheel. Remove large adjusting nut then place steering wheel back onto steering shaft. Turn steering wheel CCW & shaft with 2 steering valve bodies. Do not remove valve bodies/shims from shaft without creating very good documentation/photos of location of each component.!!!! Now with the aid of a long rod/pick & good light one can R&R the 6 o-rings taking special care to put each o-ring in the correct groove.
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2017 Ford F-450 XL (A50123)
2017 Ford F-450 XL...
Bobcat 22in. Excavator Bucket (A53117)
Bobcat 22in...
