2120 Cavitating
   / 2120 Cavitating #1
scottbennet
I have a 2120 and it appears to be sucking air. When I raise the bucket, it staggers or hiccups (hard to describe in words). From what I understand, it has to be sucking air on the suction side. I don't see hydraulic fluid leaking anywhere, but I don't think that's unusual for a suction leak. Any ideas on where it likely would be or how to find it. Thanks in advance. Scott
   / 2120 Cavitating
Thanks. I changed the fluid (and the filter) last winter and put only 100 or so hours on it this year until it started doing it a couple of weeks or a month ago.
   / 2120 Cavitating #4
don't have alot of water ( frozen? ) in that sump do ya?
soundguy
   / 2120 Cavitating #5
If memory serves another New Holland owner had a problem somewhat similiar. He tightened his filter a quarter turn and his problem went away. You may try this prior to changing the filter.
   / 2120 Cavitating #6
is the oil looking foamed.. does the foam settle out or is it emulsified?
soundguy
   / 2120 Cavitating
Thanks guys for your help.
To specifically answer your points:
1. 電on't have alot of water ( frozen? ) in that sump do ya? - doubt it. Problem started before freezing temps. How would I tell ? Drain it ?
2. 的f memory serves another New Holland owner had a problem somewhat similiar. He tightened his filter a quarter turn and his problem went away. You may try this prior to changing the filter. -- Will do. Problem started well after fluid/filter change. But checking tightness wouldn稚 hurt.
3. 妬s the oil looking foamed.. does the foam settle out or is it emulsified? -- I did check this after the problem started. No I don稚 see any foaming. But I was pulling the dipstick. Is there a better way to check?
I would like to note that one of the loader lift pistons is leaking and the end (whatever that痴 called) appears to be a bit loose. I did ask someone locally and he indicated that wouldn稚 introduce air into the system.
Any more thoughts would be appreciated
   / 2120 Cavitating #8
draining some oil from the sump into a jar after running it will tell you if it is emulsified.
soundguy
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
E-Z Flow Auger Wagon (A50514)
E-Z Flow Auger...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2018 CHEVROLET SILVERADO TRUCK (A51243)
2018 CHEVROLET...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
