2028 century hydraulics quit working
/ 2028 century hydraulics quit working #1
rogerdodger
skiatook oklahoma
2002 century 2028
i have been using my tractor moving tree limbs when all my hydraulics quit working front end loader and box blade will not lift i changed fluid and filter still nothing any clues to what went wrong and how to resolve?:confused2:
/ 2028 century hydraulics quit working #2
Check your pump to see if it's turning.
Use a hyd gage and check your pressures.
thanks j_j my pump on this model is gear driven and also runs a separate pump for power steering which is working fine but has a seperate reservoir
/ 2028 century hydraulics quit working #4
Is it possible you could have hooked one of the hoses with a tree branch and partially unplugged one of the quick disconnects.
/ 2028 century hydraulics quit working #5
Remove a complete QD fitting from the hose going to the first QD and place in a bucket and see if you have hyd flow.
If so , check the hyd pressure.
took high pressure line off feed block to front end loader nothing there guess pump went out:thumbdown:
does anyone know what make the hydraulic pump is on a century tractor 2028? cant find the name on pump
/ 2028 century hydraulics quit working #8
Check the spline, keyway or coupler to make sure it's turning the shaft
Pix..??
Didnt know if i wanted to tear it apart if i couldnt find another pump if i needed it
/ 2028 century hydraulics quit working #10
I looked at the parts breakdown on the bBranso sight and all it says is 13 cc. I have looked at my Branny 2400 and can not find a number on it either. I would suspect the drive shaft is spline so it is possible the splines are worn or a coupling has slipped. I couldn't tell were or how the pump is mounted but if out in an accessable area where you don't have to drain the tranny I would remove the pump and look for obvious damage. Gear pumps are usually pretty tough so suspect something in input drive broke.
/ 2028 century hydraulics quit working #11
You're better off yanking it apart on a scouting mission if it's dead anyways
/ 2028 century hydraulics quit working #12
Have you checked the suction hose.
Perhaps you lost the prime.
thanks for your input will take pump off as it is on outside of motor in front easy to get to but sometimes looking at it and actually getting it off can be two different things i will look at suction hose first though before tearing it apart thanks guys
:confused2:Well took pump off it turns although is very stiff and feels kind of like is grinding put back on and if put fluid in hose and let it feed it works after hooking feed line on it doesnt work . Seems like it isnt pulling fluid from reservoir to feed could the suction be out? and if so probably need new pump right? i've done everything i know of to make sure there are no blockages in feed line and i'm pretty good at taking this thing apart now thanks:confused2:
/ 2028 century hydraulics quit working #15
If you remove the suction hose, does the tank try to drain?
Is your suction hose good from tank to pump IN port?
If you have a screen in the hyd system, remove it , clean it and replace.
