2025r loader reattach
/ 2025r loader reattach #1
tld
Boston, GA
JD 2025r
Taking loader off was no problem. After a month I try to reattach and seems loader latches are too low to go into the tractor bushings. If I drive forward my suspension hits the parking stand. Seems like the stand needs to be back further and loader needs to be lower.
Any ideas? Thanks.
/ 2025r loader reattach #2
Sounds like you are trying to place the loader onto the upper locking pins instead of the lower ones. Take another look, if the loader has not collapsed on the stand make sure you are aligning with the lower mount.
The tractor will not get close enough to the loader to hook up anything. The tractor tie rods hit the parking stand.
/ 2025r loader reattach #4
Assuming you are on a level surface. Perhaps the cylinders have bled down. You should have enough slack in the hoses to attach to the tractor and then use the hydraulics to ensure it is fully extended into the park position. If you cannot get close enough to hook up the hoses try parking beside the loader and attaching the hoses.
Yes I lack about a foot straight on but can park beside.
I think I did not detach it correctly and did not get the stand back far enough so I can drive up far enough to attach.
/ 2025r loader reattach #6
There are videos on the JD website that will show you exactly how to take it off and put it back on. There are also youtube videos. Give them a shot, it might just help.
2024 Honda CRF 450RL, VIN:JH2PD1117RK500228 (A61166)
2024 Honda CRF...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
FERGUSON 21 (2) ROW PLANTER (A62130)
FERGUSON 21 (2)...
case 370 glass door never installed (A61307)
case 370 glass...
KBH Tender (A63118)
KBH Tender (A63118)
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
