2023 or 2030?
/ 2023 or 2030?
Wow ok, so my wife and I went out to the property today and really walked the entire perimeter with the previous owner (theyre renting the place from us until they move to their new place in July) and finally got a real good look at the entire place. The first 3 times we viewed the property there was snow on the ground, and the 4th time we saw it prior to closing I had just had a surgery and was in no shape to walk the land...
Walking it really well really helped give me a better idea what the tractor will help with, what I saw was:
1. I'll need a bush hog for sure. A lot of the property is cleared and about half the cleared property is nice smooth lawn, the other half is more of a rough cut lawn...wont mow it often, but will need to knock it down every now and then. Originally I was planning to get a ZT mower to handle the lawn (and still will for the smoother sections) but a bush hog will really come in handy for the other parts.
2. Some areas down lower towards the road are quite wet...it's also the worst time of year for that (snow melted and raining a lot) so Im thinking it wont be super wet year round...but Ill have to deal with a bit of slippery stuff in spots.
3. The driveway will require maintenance from time to time...it was kinda smoothed out with snow all the past times we looked at the property, but now that its all gone I can tell it will end up a bit too bumpy each year...will need to grade it or at least run a rake over it.
With all that said...Im still really leaning towards the J2023 but wanted to update my post with more recent info. My biggest recent concern is: will the 2023 handle a bush hog ok? Or will it be struggling to cut through the thicker stuff with that?
/ 2023 or 2030? #22
The 2023 will handle a 4ft heavy duty brush hog with ease or a standard duty 5ft. As long as you're only cutting grass, the 5ft should be fine. If you need to chew up saplings and thick growth, might want to drop down to a 4ft.
/ 2023 or 2030?
So the 2023 is pretty much 100% at this point...havent been able to find any reason not to go with it yet!
My next big decision is whether to go for the backhoe or not...it would be nice to get it at the same time so I can include it in the financing...but they arent exactly cheap. Im sure I'd get use out of it, but its nothing I couldnt do with a hand shovel (mostly planting trees/shrubs).
Can anyone speak for the quality of the LS backhoe? Worth the money?
/ 2023 or 2030? #24
Blstr88, I haven't used one of the backhoes for the J2023/2030, but I have been up close to them. They are built very sturdy for a tractor of that size. Check with Olympus here. He has one and has used it on his J2023. Seems like he went beyond recommended limits IIRC, but still didn't damage it.
That is one good looking tractor. Too bad they don't offer Ag tires for it. I was hot and heavy on it myself until I found out it doesn't have that option.
Good luck with your choice. I'm still on the fence as to which one I will finally select.
/ 2023 or 2030? #25
The backhoe seems solid to me. I dug up a pine stump that is about 18 inches across at waist level, without any problems. The pressure relief seems set low so it does not move the tractor much, but it still digs well. I am moving up to this one from a much smaller backhoe though. There is some movement on it, and the post for the seat touches the cross beam, I can see where it is swapping a little paint.
It is simple to remove from the tractor, also. It only took a few minutes. I doubt it will be hard to reinstall either.
/ 2023 or 2030?
Thanks guys. I definitely want it, just gotta decide if it's worth the ~$6000...
We're planning to plant a LOT of various fruit trees, bushes, shrubs, etc at our new property this year and over the next few years...so if nothing else it would really help with that.
/ 2023 or 2030? #27
I actually decided not to get a backhoe. For as little as I would use it, I couldn't justify the price. I can rent one a lot cheaper and get a project knocked out if I need to. They are very good quality hoes though. It just depends on your needs and how often you'll use one.
/ 2023 or 2030? #28
I have found, from experience, that for planting smaller trees, a post hole auger works better than a backhoe. Whatever you dig out, you have to put back by hand, and the backhoe will dig a lot more dirt than you need.
For a snow plow, I had a skid steer quick attach put on the loader, because it is a lot less expensive to get a plow for a skid steer then the one for the front of the tractor. It also allows me to use pallet forks, a grapple, and a hay spear.
Even though it does not say so on their website, you can get R1 tires for the J2023H. Ask the dealer about them. I was about to get them, but decided not to because I need the tractor for plowing snow on my dirt driveway/asphalt road. They will tear the dirt part up, and they wear a lot faster the R4s do on pavement.
/ 2023 or 2030? #29
"Even though it does not say so on their website, you can get R1 tires for the J2023H. Ask the dealer about them. I was about to get them, but decided not to because I need the tractor for plowing snow on my dirt driveway/asphalt road. They will tear the dirt part up, and they wear a lot faster the R4s do on pavement. "
Hmmmm. I've asked two different dealers in North Carolina, and also asked the people at the LS assembly plant in Battleboro, NC about the R1 tires. They've all said R4 or Turf tires, no R1 Ag tires. This was the primary reason I decided against the J2023 tractor. The rims are different for R1 & R4 tires, Very different.
Could you find that information and post it here?
/ 2023 or 2030? #30
I talked to Jeff at Barlow AG in Pennsylvania. Here is his email:
barlowagsvc@gmail.com
I double checked in my emails with him, I had said I did not think it was available, but he said he could order them.
/ 2023 or 2030? #31
I just e-mailed another LS dealer in Salemburg, NC to check again. I'll also e-mail your contact. Something is crazy here. Of course, there was a rumor of a J2027H tractor at one time too, so take that with a grain of salt. :p
/ 2023 or 2030? #32
From e-mail from barlowagsvc@gmail.com: "It is true that LS does not offer an Ag tire for that model. I think you could order one on a skid with bare rims and go get ag tires at a tire supplier if you want to go through that trouble. I am sorry that this is not an option that is factory available.
Thanks,
Jeff
Barlow Ag"
I'm still waiting on another e-mail confirmation from a different LS dealer in NC. I think we're getting misinformation along with mixed tractor series. Believe me, I do wish the J2023H/J2030H did have the R1 Ag tire option. It would be all I'd need. :confused:
/ 2023 or 2030? #33
I just had my 2023 filled with Rim Guard yesterday. It's like a completely different tractor. You wouldn't believe the difference it made with traction. No more needing 4wd unless I'm doing loader work. It was money well spent and should be standard with these tractors.
/ 2023 or 2030? #34
I was really interested in hearing what difference it would make for you once you got the tires filled Olympus. This is good to hear because, like windcatcher, I was concerned about the lack of traction you were getting with the industrial tires. Even if ags were an option I wouldn't be crazy about having them because of the damage they can do compared to industrial. Glad it made that much difference with the Rim Guard.
/ 2023 or 2030? #35
I had them filled to 75% which I think was about 15 gallons per tire. It added about 300lbs to the rear tires. I played around with it a lot yesterday and I didn't slip a tire a single time unless I was using the bucket to dig with. I added metal valve stems to the rear and it was $150 for everything.
/ 2023 or 2030? #36
Olympus, I'm really glad to hear this has worked out for you. Did I read correctly that you only filled the rear tires? I'm wondering what the tractor would be like with all four tires filled. That to me would have to give better traction on top of what you now have.
/ 2023 or 2030? #37
There's no reason to fill the front tires. You have 500 lbs of boom and bucket providing weight on the front axle. When 4wd is engaged, there is no tire slipping with either the front or the back.
You fill the rear tires so they don't slip and get better traction so you don't have to run in 4wd nonstop.
/ 2023 or 2030? #38
That's good to know. Do you think you'd get stuck in wet, swampy, slick clay ground? That's the kind of land I am working with.
/ 2023 or 2030? #39
I have loaded r4 tires on my R4047
It will still slip and slide in clay
/ 2023 or 2030? #40
As a tractor owner, you need to learn when to leave your machine in the shed. Any tractor will get stuck depending on the conditions. A bigger tractor or R1 tires are not the answer to every situation.
I'm confident that my tractor will no longer get stuck AS EASILY AS BEFORE now that I have the rear tires filled. But it will still get stuck if the conditions are too wet and I push the envelope. If the conditions are wet enough that you're cutting ruts, you probably shouldn't be working even IF your machine doesn't get stuck. If you're cutting ruts, your making just as work as your accomplishing.
