2021 L4060 HSTC Limited Edition Tilt and Trim Help!
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #41
I missread you then. If you're thinking a box blade (which I was), that doesn't angle may or may not have rippers. If you're thinking a rear angle blade, you should consider a 7' or wider, so you cover your tire tracks when angled.
Sorry if I got you confused.
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #42
Congrats on the new tractor.
I'd let the dealer install all of it.
I installed all of mine but I'm open station. Cab setup will be more difficult.
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #43
Am I to understand that a $37,000+ Grand L series kubota doesn't come with rear remotes standard? jeez, man.
Edit: I built one on the Kubota site, looks like a pair of rear remotes is about a $1600 option.
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #44
I assumed it comes with one. But your search maybe reveals it does not.....
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #45
As far as Kubota, no std rear remotes until an M6060. MX series and everything smaller is an option.
Correct and that sucks as much as these costs.
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #47
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
2008 Ford F-250 Service Truck (A56858)
2008 Ford F-250...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
(10) UNUSED SDLANCH 2.5CM X 3.5M RATCHET STRAPS (A58375)
(10) UNUSED...
ELECTRIC GOLF CART (A58216)
ELECTRIC GOLF CART...
