2021 L4060 HSTC Limited Edition Tilt and Trim Help!
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #41
I missread you then. If you're thinking a box blade (which I was), that doesn't angle may or may not have rippers. If you're thinking a rear angle blade, you should consider a 7' or wider, so you cover your tire tracks when angled.
Sorry if I got you confused.
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #42
Congrats on the new tractor.
I'd let the dealer install all of it.
I installed all of mine but I'm open station. Cab setup will be more difficult.
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #43
Am I to understand that a $37,000+ Grand L series kubota doesn't come with rear remotes standard? jeez, man.
Edit: I built one on the Kubota site, looks like a pair of rear remotes is about a $1600 option.
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #44
I assumed it comes with one. But your search maybe reveals it does not.....
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #45
As far as Kubota, no std rear remotes until an M6060. MX series and everything smaller is an option.
Correct and that sucks as much as these costs.
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #47
30pc. 16ft.x 3ft. Black Metal Roof Panels (A53424)
30pc. 16ft.x 3ft...
2002 Ford E-350 10ft. Box Truck (A55852)
2002 Ford E-350...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Bus (A55852)
2000 Thomas Built...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
