2021 L4060 HSTC Limited Edition Tilt and Trim Help!
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #41
I missread you then. If you're thinking a box blade (which I was), that doesn't angle may or may not have rippers. If you're thinking a rear angle blade, you should consider a 7' or wider, so you cover your tire tracks when angled.
Sorry if I got you confused.
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #42
Congrats on the new tractor.
I'd let the dealer install all of it.
I installed all of mine but I'm open station. Cab setup will be more difficult.
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #43
Am I to understand that a $37,000+ Grand L series kubota doesn't come with rear remotes standard? jeez, man.
Edit: I built one on the Kubota site, looks like a pair of rear remotes is about a $1600 option.
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #44
I assumed it comes with one. But your search maybe reveals it does not.....
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #45
As far as Kubota, no std rear remotes until an M6060. MX series and everything smaller is an option.
Correct and that sucks as much as these costs.
   / 2021 L4060 HSTC Limited Edition Tilt and Trim Help! #47
203091 (A52707)
203091 (A52707)
Kubota L4701 (A53317)
2002 International 9200i Truck (A55315)
2002 International...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2004 Workhorse W22 Motorhome (A53424)
2004 Workhorse W22...
1987 Ford F800 E-One Pumper Fire Truck (A55852)
1987 Ford F800...
