2020 PTO plastic bushing
/ 2020 PTO plastic bushing #1
rmully
North Carolina
YM 2020
I need the plastic PTO bushing for a 2020...Hoye wants $15 plus $25 shipping and I am not paying that inflated shipping for that small part amount. Any ideas, have a 3D printer but can not find a file
/ 2020 PTO plastic bushing #3
I am old and slow. Define pto bushing for me.
/ 2020 PTO plastic bushing #4
Some of the plastic types look like this.
or like this,
It would be nice to see what his YM2020 really has. :)
/ 2020 PTO plastic bushing #5
My guess is it's 2 pieces SC-4130 shaft Collar & 42x609TC PTO seal. Being plastic I can't see not changing the collar.
/ 2020 PTO plastic bushing #6
What is your shipping zip code and what else is in your cart? Our shipping rates come direct from UPS.com with no added handling charges. UPS is extremely expensive these days but I did a few test orders and did not see anything close to $25.
I think you are talking about this piece?
/ 2020 PTO plastic bushing #8
I looked this one up since I never seen it come up. Had to look hard but It's there" PTOB-2787 PTO Shifter Block". Yeah I think 25$ on shipping is a little steep.
/ 2020 PTO plastic bushing #10
Try shopping locally at your tractor dealership. If you are patient enough to wait for a regular milk run you can probably pick it up at the dealership without any shipping charges.
Amazon has spoiled our expectations - shipping really does have a cost, it isn't free. If I drive my Prius it costs me $0.06/km in fuel alone to drive to the dealership so $2.40 round trip. If I drove my pickup truck it would cost me $7.20. Then I lose an hour of my day, wear and tear on the vehicles,...
$25 to be shipping half way around the world and to your door step seems like a deal to me.
FYI 3D printed plastic parts aren't going to last as long as the OEM part.
Yes that is it I will look for that part, thanks so much for your help
Halfway around the world..it is 2 states over but thank you, someone sent me a part number so I can find it
/ 2020 PTO plastic bushing #13
ok, pto cover bushing. Better make sure what cover you have before ordering.
/ 2020 PTO plastic bushing #14
For what it's worth, it is a little over 1100 miles from Iowa Park Tx to Charlette, North Caralina. If as your avatar shows, you are from North Caralina, then that would be 3 or 4 states over. If your not from North Caralina, then I'm all wet.
/ 2020 PTO plastic bushing #15
Picking UPS for this type of shipping is the issue cause.
Drop it in a plastic self-seal envelope, it ships for a couple bucks,, by US Mail.
I purchased a drill press chuck arbor last week,, it must weigh 2 pounds, and 6 inches long.
It cost ~$7 delivered, and is precision ground tool steel.
The inspection certificate was dated July 2021,, so I did not buy some "old junk"
/ 2020 PTO plastic bushing #16
Then they lost money on it. I ship with a commercial discount via usps. the cheapest that could have been sent was about 9 dollars in shipping alone. unless it took like 9 days to get to you.
/ 2020 PTO plastic bushing #17
There are 3D printed parts stronger than mid grade aluminum.
As for the part being Delrin 500, then 3D printed parts would hold up just as long.
/ 2020 PTO plastic bushing #19
is Derlin special? i saw that it was exepensive, not sure what makes is special,, is it slick?
/ 2020 PTO plastic bushing #20
Delrin is an acetal type plastic. It is slick. It is an "engineering plastic", as is nylon, which is generically known as a polyamide plastic. Though similar in strength acetal plastics don't absorb very much water as polyamide plastics do. Delrin is a monopolymer, which means it is composed of a single polymer. A similar plastic to Delrin is Acetron. It is a copolymer plastic. It is composed of two types of acetal plastics. It is more common that Delrin. Nylons can be better than Delirin and Delrin can sometimes be beter for a specific application. If the part will be exposed to water or high humidity and then later to dry conditions and then wet conditions again nylons will be a poor choice if fits are considered. This is because nylons absorb water. This water absorption will make holes smaller and larger. Acetal type plastics do not absorb as near as much water so dimension changes are usually inconsequential. The gist of this posting is that if you do get a part 3D printed don't ask for nylon.
Eric
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2018 CATERPILLAR 232D SKID STEER (A64279)
2018 CATERPILLAR...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
