Buying Advice 2020 Massey 2607H
   / 2020 Massey 2607H #21
I purchased a new 2020 Massey Ferguson 2607H a few months back and now have 50 hours on it. Thought I would post a review to help others out since Massey does not seem to promote their tractors very well, and there was not a ton of info out there on this model outside of the videos posted by the guys from Vahrenburg(spelling?) Implement. While the videos were helpful, I wanted to hear more from owner/operators.
I decided I wanted to get a 70-75HP tractor, mostly for heavy lifting around my small farm and to pull an everything attachments heavy duty box blade that I planned to get, which weighs in at over 1000lbs. I narrowed my search to Kubota, New Holland, John Deere and Massey Ferguson. (I already own a GC-1720 and could not be happier with it. Runs strong and has been a work horse for the small stuff.) all dealers are close by and redundant dealers are within 1.5 hours of me.
After researching and shopping for a number of months, I was dismayed to find that all of the tractors in this HP range are either made in Turkey ( New Holland) or India (everyone else). However Kubota was the only USA made tractor. I liked how the Kubota speced out, but the weight was the lightest of the group and the price was one of the highest. Deere felt chincy and was pricy, its rear end did not look as beefy as the Massey, and if I was going to spend that kind of money for one of those green machines and wear their hat I sure wanted it to be made in our country! Was not a fan of the New Holland. While I also did not like that Massey was not a US made tractor either, I finally accepted that if I wanted a 70-75HP tractor this was the field I would have to choose from. Turns out they put a Perkins clone in the Massey. It is also one of the heaviest in the class. Came with all the features I wanted without all the little creature comforts that get in the way on an open station work horse. Had two rear remotes from factory, a 7 wide bucket (important to me and hard to find on others), comfortable operator station, no DEF, ground level fueling and oversized R1 tires.
I went to test it at the Belle Meade Garage in Belle Meade NJ. Kipp Higgins was the owner and was a very nice guy. Let me test drive it till my heart was content. Gave me a great price on it and I bought it. They delivered it for free. Great experience!
I bought the everything attachments box blade. Excellent ballast for this machine and works great on my new home construction site- not as good as a bulldozer but not a one trick pony either. The tractor is super powerful, smooth and the Perkins Diesel clone sounds phenomenal! Love this machine. It is a shame you do not see more of these guys out there.
If you are looking for a small frame heavy weight utility tractor that can do everything and more than the competition, do yourself a favor and check out the Massey. I am glad I did
If you do your research; Which you did you'll end buying a Massey-Ferguson.I talked my brother into buying 1 & a friend of mine. I told them to go out & comparison shop, & you'll end going with a M-F tractor; As they did. Both were completely different models than the ones I own. I personaly think that most M-F tractors are bought by word of mouth, & examples that owners have IMHO.
   / 2020 Massey 2607H #22
My Eval of the 2019-2607H:
Overall I give it a 8.5 out of 10
Ive owned it from 450hrs to 900hrs
Pluses: Starts well, good power, holds up to my abuse.
Love the structure, I added extra wheels so that I can handle hills better, and more traction.
Downsides:
Tends to leak quite a bit, not just one place. was leaking at the loader controls valve (I went ahead and replaced 3 o-rings (OEM $120) and may have solved it)
Also leaks out the rear and the side plate. I have yet to open it and fix it. This is has been since I got it.
Being a 2019 it also had the weak loader valve control plate. OEM was overpriced again and was $90, found a guy on ebay that makes them for $30
Loader control electronics stick out and get caught easily. $120 to fix the little electorinc box, Im good at electronics, so I found a replacement box for $10 on amazon, and did some soldering.
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
550 GALLON FLAT BOTTOM POLY TANK (A58374)
550 GALLON FLAT...
550 (A52708)
550 (A52708)
2009 International 7400 T/A VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A56858)
2009 International...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
SKIL SAW MITER SAW (A58374)
SKIL SAW MITER SAW...
