2015 tiller
/ 2015 tiller #1
Durbob
Can a 2015 handle a tiller wider than outside its tires width? I'm guessing 5' anyway. Or is a 5' tiller even wide enough?
Thanks
Dur
/ 2015 tiller #2
No
Most tillers are able to be off set and then the track of your tires doesen't matter.
Is your tractor a gear or hst?
I would not go much bigger than a 55"
If it was mine I would run a 48"
The bucket that is ran on that machine from the factory is a 48"
Which means a 48" tiller will cover your tracks.
/ 2015 tiller
</font><font color="blue" class="small">( No
Which means a 48" tiller will cover your tracks. )</font>
I don't own one yet, but just checking out to make sure that it would handle a tiller wider than its tracks. It does seem to me that size of tractor could could use a couple more hp for its frame size. Thanks for the reply.
Dur
/ 2015 tiller #4
SURE ! if its a japanese tiller it would work on a 2015.
Like a Yanmar 1300 tiller with wheels on it.
They are nice and light & would make powder of the soil.
just my .02
Ernies imports
/ 2015 tiller #5
I suspect Ernie is right. 1300 mm is about 51 inches and will cover the tires. We generally suggest a 48" with a small offset, but in most soil conditions they will run a little larger tiller.
/ 2015 tiller #6
Hi, I own and use 48" tiller with geared 2015. Last week I used my friends 5ft tiller with my tractor, (mine need new bearing). I could not tell any difference in the workload.... BTW, both, are yanmar grey market tillers. Hope this helps.
/ 2015 tiller #7
Have sold a few 2015 hst, with the Befco t-30-50, 50" with offset capability and it works well. As far as 60" goes, i think its a little large in my opinion, but that also depends on what you are tilling. Virgin ground, hard clay or light humus type soil in a garden.
If you are using it in a garden with nice soil not a lot of rock, should work ok.
- If you have soil like in the Troy built tiller comercials where the guy can till with 1 hand( not around here) you could probaly go bigger. /forums/images/graemlins/grin.gif
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
(10) New CATERPILLAR Keys (A65579)
(10) New...
