2015 John Deere 5075
/ 2015 John Deere 5075 #21
I changed the hydraulic fluid & filter in a 5093E with 700hrs & fluid was clean as a pin with very little contamination on the screen filter.
Overkill imo less than 7-800hrs
/ 2015 John Deere 5075 #22
JD recommends changing the fluid after the first 300 hours, then I think every 600 hours. Obviously it was an issue for me, and I was told by the mechanics at JD that screen clogging is a pretty common issue that they see, and that I could either pay them to fix it, or change the fluid, and clean the screen off myself. I think I changed mine at like 220 hours, and it was maybe 150-160 hours when I started experiencing the issue. After changing it, no more squealing and whining, and it now goes F to R without kicking into neutral all the time. I mean if you've got 400+ hours and you've never changed your transmission fluid in a 10 year old tractor, it's not a bad idea if you're having transmission issues anyway. Your tractor's good and broken in by this point. You're likely going to have some metal in there from everything wearing into itself. Mine absolutely did. But do as you will I guess.
/ 2015 John Deere 5075 #23
I understood the first screen cleaning to be a time to catch the filings and debris from the manufacturing process of all the parts and after the first 50 hours not as necessary.
My 4300 first screening was around 100 hours and the screen was not completely plugged, but had plenty of steel and other filings. The next two screen cleanings were after 500 hours and the screen was quite free of any of such debris.
Also have heard there is a process along the assembly lines or just prior to getting to the assembly line that parts are cleaned up much better than when my tractor was assembled in the late 90's.
/ 2015 John Deere 5075 #24
JD recommends changing the fluid after the first 300 hours... After changing it, no more squealing and whining, and it now goes F to R without kicking into neutral all the time …
Not arguing at all but I don’t see a dirty screen kicking trans into neutral.
That’s more of an electrical problem I’d think.
/ 2015 John Deere 5075 #25
The only issue my 18 5075E ever gave me was my shuttle wouldn't go forward to reverse and vice versa without kicking into neutral, or using the clutch. It would also humb or squeal sometimes. Turns out the screen filter in the transmission likes to clog especially during breakin, and changing the trans/hydraulic fluid sooner than the manual recommends is a good idea. Basically it was just restricting oil flow which was my issue. If you've not changed your trans/hydraulic fluid after 400 hour it would be a good idea. That screen inside the transmission definitely picks up a lot of trash, and debre.
It's located behind this cover by the PTO shaft.
Interesting looking screen and location, by any chance do you also have a similar 2 or 3 bolt cover under the rear housing?
The reason I ask is that I have heard that JD used the Branson rear and transmission in some of it's 5000 series tractor. That looks just like the screen in my rear housing that feeds the shuttle clutches of the transmission. And I also have a magnetic plug in the bottom of the housing.
/ 2015 John Deere 5075 #26
I think it was an issue with improper flow is all I can guess. It would shuttle if I was going slow, and babied the F to R or vice versa, and not just quick throws, but during normal operation it would kick the neutral. The high pitched whine was worse than not shuttling, as I could use the clutch when going between F and R and it would work. The loud whine wouod start and usually last 20-30 minutes, then go away for a while, and then start up again. I have a video of it on my phone, but can you post video on here off your phone without uploading to a host site?
/ 2015 John Deere 5075 #27
I'm not sure off the top of my head. I thought Deere introduced the power shuttle transmission in this class of tractor with the 5X10 series back in the late 90's, maybe 99 I think? I think Deere was the original ones to introduce it in this class, but I can't guarantee that. I assume it was the same basic transmission used today, as it was a 12x12 shuttle with 3 ranges and 4 gears, but again I can't say that for certain.
/ 2015 John Deere 5075 #28
Did you check Trans fluid level? We need to get back to basics on everything.
/ 2015 John Deere 5075 #30
John Deere 5075 maybe 425 hours broke down in the field on Saturday. Display said NEUTRAL. Transmission disengaged. Walked back to barn. Any ideas ?
anybody ever chk the trans fluid?? maybe when its low , it shuts down??
/ 2015 John Deere 5075 #31
Thats exactly what I had to do. The tractor simply went into neutral for some reason. Dealership here said "check" for a disconnected wire under the tractor and check fuses". I have done these things. Fuses are good and didn't see any broken wires.
maybe foot pedal linkage is loose??
/ 2015 John Deere 5075 #32
^^^ Along this same line of thinking, are there potentiometers in use for the travel pedal(s)? Computers MUST be able to talk to sensors and if something ain't right they get scared and bury their heads (refuse to do anything out of fear of allowing operation with undetectable inputs- pretty much as any new car/truck works).
/ 2015 John Deere 5075 #33
Have you tried resetting the computer? Disconnect the battery, turn on the lights to drain the residual power for 5 minutes, and then reconnect the battery. This sometimes works and is what the dealers will do first.
T-
Trans fluid ok. Wire pulled loose under the cab, which shorted a 10amp fuse. So, it was an easy fix for the Somerville, Tennessee JD service tech.
/ 2015 John Deere 5075 #35
Thanks for closing this out with report of the problem and the fix. Good to hear the Bandit60 is back in business.
/ 2015 John Deere 5075 #36
I have a jd5603 that shut down in the field and would not restart. Checked all the obvious electricals and found nothing. Finally called jd service tech who found a faulty temp control sensor. Apparently it sensed the engine was overheating and shut itself down. Replaced the sense and all was well.
/ 2015 John Deere 5075 #37
On most models when that temp sensor on the thermostat housing fails it blows a 20 amp ignition fuse.
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
Tree Boom Skid Steer Attachment (A61572)
Tree Boom Skid...
UNUSED WOLVERINE TDB-11-84W-84" BUCKET (A64281)
UNUSED WOLVERINE...
Kuhn FC400RG (A60462)
Caterpillar 416-442D Backhoe Service and Parts Manuals (A63117)
Caterpillar...
