2014 Silverado/Sierra released
   / 2014 Silverado/Sierra released #101
I am not really criticizing it as much as others, merely pointing it out. I would love a newer truck, I don't however want to pay $500 for 5 years to own one! I like ford and chevy though.
I also pointed out the scenario about my friend who also is a GM guy, just to illustrate that there IS a problem. This guy is a certified mechanic for a living so I don't think it was a maintence neglect issue. Also the dealership said there was an issue with the 08 and newer vehicles having problems with burning oil and rings welding to pistons.
I am neither going to buy a new ford, toy, chevy, dodge, or anything.... im just to cheap and rather spend money on other stuff. My current vehicles get me where I want to go, after all that's the point, all I want is a truck that's reliable and does what I need it to. Big deal if I cant drag race with my tractor behind me or peel out with a trailer of firewood attached.
   / 2014 Silverado/Sierra released #102
I looked at those steps when I bought my Ford....look nice but I bet they don't hold up over time. Plus it kinda takes away some of the utility of the tail-gate. I'm betting the step-bumper is much more useful in the real world. Of course, if you just pick-up groceries and the occassional sheet of plywood (like about 85% of truck buyers) I think the "man step" is a great idea. I would have to see the step-tailgate in person before wanting one though.
I have the tailgate step on my '12 F-350 4x4 SRW. I'm 5'-10" and the tailgate is above my waist when folded down. That's a pretty tall step when you are carrying something or you have to make repeated trips in and out to load or unload something. So for access to the bed to get to my tool box or stuff up in the front of the bed that can't be reached from standing alongside the truck I think it works great. Since my truck is a 4x4 the bed rails are at my armpit height which means reaching into the bed even on tip toes doesn't work most times. Now if they were smart enough to extend the running boards back to the front of the rear wheel well you'd have a place to stand and reach inside. I fail to see why they don't do that. You can get aftermarket running boards like this so why doesn't Ford offer them.
However, it screws up the inside face of the tailgate which is no longer flat. That has been a PITA when hauling sheet goods and when loading/unloading as you can't slide anything across the bed. And it offers a number of places for dirt or small stones and such to make their way under the post when folded down. I wonder long term how the step itself will hold up and if there will be problems with the tailgate because water and road salt has a new path to the inside of the tailgate. 4 years from now will the latch on the step still be tight so that I don't have to listen to the step rattling as I drive down the road.
So after owning this truck for almost a year now and despite convenience it offers I do not know if I would get the tailgate step again. Right now I am leaning toward no, but if its still working well after 2 or 3 more years I might consider it on the next truck.
   / 2014 Silverado/Sierra released #103
Two were 2500 series with the 6.0L. All in all they were good to him but we once tried to use his 2003 to put in and out my boat, 15,600#, which was over the 12,000# tow rating I know but it would not pull the boat from the lake in 4 low.
Chris
I have a VERY tough time with this statement. You honestly expect us to believe that a 6.0 GM does not have enough power to pull a #15,600 boat out of a lake, in 4 LOW yet to boot, with a 4:10 rear? And you qualify this with:" Well it was over the 12,000 tow rating".
OTHER than your anti GM bias posts, as a rule I agree with you, but these statements are over the top.
By the way I did own a 6.0 GM with a 3:73 rear. I can GUARANTEE you it would have had no trouble pulling your boat from the lake.
   / 2014 Silverado/Sierra released #105
15,600# is a lot of dead weight to get moving from a dead stop on a 30deg incline. I was not in the truck, he was, but he said the tach was at nearly 5000rpms and no move. My buddy Vallis brought down his Suburban and just a little tug got him rolling then he was home free.
Chris
   / 2014 Silverado/Sierra released #106
My 08 Nissan Titan has factory running boards that do just this, extend to the front of the rear wheels. Very handy.
Chris
   / 2014 Silverado/Sierra released #107
Chris
I am no stranger to pulling heavy loads. So you are stating that this vehicle was in low range with the motor turning 5000 rpm with no movement, **** the tires should have been SMOKIN! UNLESS the trans was slipping...
   / 2014 Silverado/Sierra released #108
Yeah story not adding up to me, probably wasn't getting traction. Chevy's fault all the way :confused2: .
   / 2014 Silverado/Sierra released #109
true, if the engine is revving to 5k, it obviously has the power- traction or tranny issue then. I would guess the trans is starting to go, and not building enough line pressure to get the power through the torque converter or is slipping. Though with that much slipping, the trans sure wouldn't last too long.
I know with my truck, if I am overworking it, the engine simply won't get to a high rpm. Sometimes I will be on a grade with my foot to the floor and it just won't get above 2500 RPM, and I have to downshift because for whatever reason the trans didn't do it itself.
   / 2014 Silverado/Sierra released #110
I'll admit, I am quite dissapointed. You would think they would have released at least ONE new engine, but all they did was dress up old engines (minus the 6.2 which in my opinion they have ruined by putting on AFM). The "all new" stuff they're touting is either cheesy or has been around since 2005 (torsion bars in the tailgate? ummm, that's standard on ALL trucks now, geniuses). Can't believe they kept the 4.3 v6 and didn't go with the 3.6 instead. No turbo, no diesel, no new engines, nothing to see here.
PickupTrucks.com - News
The 4.3 is ALL NEW. It only shares the number with the old one. The 3.6 is a CAR engine, will not live up to hauling. The 5.3 is all new too, and major changes to the 6.2L. You can thank the tree huggers in kommiefornia for crap like that. Mind you, once you are buying $6 gas like us, you will appreciate the savings.
As for an ecoboost, look for the 5.3 to match or better the ecoboost. I do not want turbos on a gas engine. The ecoboost has not proven itself,when they will last 350,000 miles minimum like the LS engines do, then it will be credible. Until then, it is a yuppy engine for a yuppy truck.
The 4.5 babymax is ready but will they release it? Would be nice.
The HD's will be finished off this year, but with the higher weight ratings coming, and the increase in power, I do not need an HD.
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
Mini Forks (A50322)
Mini Forks (A50322)
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
