2014 P7010C Speaker Size?
/ 2014 P7010C Speaker Size? #1
charles todd
Louisiana
LS P7010C, Farmall 504, Allis Chalmers 180, Komatsu PC38UU-2
What size speakers are in the 2014 P7010C "New Style" cab? I have a feeling they are going to need upgraded to 2-way or 3-way speakers. Maybe even a small powered sub behind the seat. Nothing wild, just something to enjoy some Classic Rock with while tractoring. I have not really checked out the head unit fully yet. But it seems to at least have a USB port for a thumb drive and maybe even an AUX port or Bluetooth. Its a Sony head unit.
Which make me wonder if the head unit is dealer installed, distributor installed, or factory installed? I have seen Pioneer, Sony, and Panasonic in the LS tractors I have looked at. No rhyme or reason of what brand radio or what series tractor.
CT
183 views and no one has upgraded their speakers? Guess I will have to remove one and measure the diameter and see how much depth there is to work with.
CT
nvmyhd, the link is broken. But I do appreciate the advice! I'll just unscrew a speaker grill and check it out. I'm going to have to probably pop the to up anyway. I broke my antenna somehow over the weekend. Less than 20 hours and I'm reduced to two local stations. :(
CT
/ 2014 P7010C Speaker Size? #5
I broke my antenna the second week I owned mine, it's make of fiberglass and is will not hold up. It's also very expensive to replace so I just bought a universal rubber mount one.
CT
/ 2014 P7010C Speaker Size? #6
I broke my antenna the second week I owned mine, it's made of fiberglass and is will not hold up. It's also very expensive to replace so I just bought a universal rubber mount one.
CT
Whispering Oaks, I priced the OEM fiberglass antenna. It was almost $60. I will replace it with a "rubber duck" antenna eventually.
Did you point yours up, or keep it horizontal to the rear like the OEM antenna?
CT
/ 2014 P7010C Speaker Size? #8
Haven't replaced my speakers yet but also broke my antenna the first week I had it. Caught a low hanging pine branch and snapped it. Fortunately it only broke the fiberglass and the wire was still attached. I put a piece of heat shrink tubing over the antenna and heated it till it shrunk down around the antenna. 8 months later it's still working. Poor location for the antenna since so many of us have broken them.
/ 2014 P7010C Speaker Size? #9
I ended up making a rubber antenna work in the original location and made a new 90 degree mount. I don't like it yet so I am still looking for a quality replacement.
CT
