2014 Kubota BX1870 Tractor - Engine bogging down and stalling.
   / 2014 Kubota BX1870 Tractor - Engine bogging down and stalling. #1
Shane Hanna
Indiana
Ditch Witch
2014 Kubota, I cleaned fuel tank, changed fuel filter, changed air filter, replaced fuel pump, added new diesel fuel (just a little to test), I am baffled at why this is happening, but I am positive someone else will know. I appreciate any suggestions, thanks in advance. It does it at idle, full throttle, seems to be worse under load, but it also seems very random. Here is a video of how it is acting:
New video · Sunday, Nov 30 ð¬
   / 2014 Kubota BX1870 Tractor - Engine bogging down and stalling. #2
I believe the BX tractors have (2) fuel filters inline. Did you replace both of them? It sure sounds like a fuel delivery issue.
   / 2014 Kubota BX1870 Tractor - Engine bogging down and stalling. #3
Many yrs ago I owned a M4900 that the engine bogged down even after changing fuel filter, cleaning water separator screen. Local Kubota dealer service manager advised me to check for clogged screen in fuel control valve in water separator housing. I removed retaining screw then removed control valve & located the tiny screen & it was clogged. Cleaned screen & bogging problem was solved.
   / 2014 Kubota BX1870 Tractor - Engine bogging down and stalling. #4
Also check and see if there is a hose kinked ...
   / 2014 Kubota BX1870 Tractor - Engine bogging down and stalling. #5
Fuel supply issue..
Does your machine have a supply pump.??
I think I remember seeing something about a 2nd filter under the tractor..??
Yes, I actually upgraded to a fuel filter water separator combo like 4 years ago, so I think I am good there. Thanks.
   / 2014 Kubota BX1870 Tractor - Engine bogging down and stalling. #7
Are you 100% sure you still don’t have one of those little filters somewhere? There is originally one under the tractor towards the back and one up near the injection pump. When I had a BX I also upgraded and put a Racor unit in but still had the little white one underneath.
   / 2014 Kubota BX1870 Tractor - Engine bogging down and stalling. #8
This shows 2, both same part number ... One on engine, one between the frame rails ...
Yes I removed the one below, it was a pain to change, and one of my biggest reasons for upgrading.
Has anyone cleaned or replaced their fuel injector nozzles, this is the only thing I feel like is left.
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A58375)
2018 CHEVROLET...
Trimble Surveying Equipment Mounting Posts (A55973)
Trimble Surveying...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56436)
Dual Tailwheel...
2025 JMR 66in Single Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 66in...
2025 Swict 78in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 78in...
(2) CUTTLER HAMMER 200 AMP DISCONNECT (A52708)
(2) CUTTLER HAMMER...
