2014 Hay Season
   / 2014 Hay Season #131
Jim, that was mean. Very funny, but mean. .
Aw a little bit of ribbin' never hurt anyone!!!!! I've seen JD rd bales stacked on "flat side" in a barn but they used a bale grabber(clamp). All I'm going to state is it takes a "DARN TIGHT 4X5 grass hay bale" to weigh 1000#s that will test 15% or below moisture!!!!!!!! I've bought several 18 wheeler loads of 4X5's and a few 4X5.5's that would not weigh 1000#s each
   / 2014 Hay Season
Hey Jim where you find those JD 530 parts break down from in other post if you don't mind. My buddy just picked up one and we been going threw it but don't have a manual(got one on order), think roller need is going to be a tension roller,its on the arm with the other 3 at end of it.
   / 2014 Hay Season #133
JDparts.com parts catalog #1915 for 430/530 rd baler
   / 2014 Hay Season
I counted today and have 308 bales put up and have another 20acre pasture to go. I think that's all going to keep,have buyers for 90bales,when I make more. We ended up with 2.90 in the rain gauge today so will be cutting my other two pastures again also(55acres). With all that's being made I'm sure demand will go down and be hard get rid of it all.
   / 2014 Hay Season #136
Typical hay story of supply & demand. Only problem is input costs(fert.parts,fuel & cost of equip) remain high but good rains do help to raise BPA average. How much do you price your fert. bales for???
   / 2014 Hay Season
I priced them at $45 but the guy seen the pasture they are going to come out of and doesn't have a weed one and knows it's been fertilized good. I will have some other to try and get rid of later,that will probably go for less to get moved.
   / 2014 Hay Season #138
So would you take $85 per ton if I can locate you a buyer???????????????
   / 2014 Hay Season
Let me see what going to make and not go local.
   / 2014 Hay Season #140
looks like with the rain weve had so far that we are going to get another cutting on 30acs if we want to cut it.
2757 (A55787)
2757 (A55787)
TANK MANIFOLD (A55745)
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
Miller Millermatic CP/CC-1500 Industrial Welder  Heavy-Duty Power Source (A59225)
Miller Millermatic...
2025 J and C 6X12SA 12ft S/A Enclosed Trailer (A56859)
2025 J and C...
2014 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2014 UTILITY VS2RA...
