foreman Etexas
Elite Member
- Joined
- Jul 7, 2011
- Messages
- 3,334
- Location
- texas
- Tractor
- Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
Ive felt like you in prior years -- problematic cutting. You shoud check out a Drum Mower. I got mine to replace a haybine at the end of last season and tried it on a few acres. Fast - cuts everything - never clogs -- much less$ than a discbine and should work on your tractor [fine on our L3450]. ... I think itll even do fine in wet grass. Im looking forward to this year.Our grass is just turning green here in western pa! I'll admit, I'm not really looking forward to hay season this year. Although, I think im going to be much better prepared with the stub guards shimmed correctly in the NH499! Some yahoo had anywhere from 0 to 6 shims in there. No wonder I had a heck of a time last year with it with grass packing in under the hold down clips. I need to upgrade tractors before I can jump into a discbine though.
So I got everything drug out and going over it all. Desided to go ahead and cut the front yard and bale,getting everything going to start thursday on the big fields. It made a biggen:laughing: View attachment 373115
Nothing this year--only 10 inches of rain since last Oct (normal is 18"). My 6 acres is dry farmed so no go.
My neighbor just baled and stacked hay on his 8 irrigated acres (forage mix plus vetch). Result: about 2 tons per acre.
He planted in mid Nov last year, irrigated three times in Jan. Paid the irrigation district $41 per acre foot then. As of 15 April the price is $625 per acre foot. We're in the third year of drought. Sierra snowpack supplies water to the irrigation district via Shasta Lake and the Sacramento River. Snowpack has been below 50% of normal for the past several years.
So everyone from orchard growers to alfalfa farmers around here are pumping ground water like crazy. Hope I don't have to deepen my well.
well we just swallowed hard and ordered 4 tons of 17-17-19 fert.and that stuff is high $552 a ton.
At least for nitrogen, I've read that even if you need substantial amounts, it's best to apply at no more than 100lbs per treatment due to loss by run-off. This would mean making multiple applications over a period of several months for the best benefit.
Also, just curious, do you guys routinely spread dry fertilizer or do you ever go with a spray?
Yes? No?
Yeah usually dry first time, then second liquid with weed killer mixed in.
Have you found a source for the liquid that is a "best price?" From what I see, weed control is a bit less expensive but especially fertilizer is like liquid gold - lol.
