2014 3500HD button on dash. What does it do?
/ 2014 3500HD button on dash. What does it do? #1
Hay Dude
Epic Contributor
The Last Red State in the Northeast
Challengers: MT655E, MT555D, MT535B, Massey 7495, Krone 4x4 XC baler, 2-Kubota ZD1211’s, ‘20 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 38K trailer, Deere CX-15, 2 Pottinger Hay mowers, NH wheel rake, Claas 30’ tedder
Still truck shopping for an HD.
Have seen a few with this button/knob. What is it for?
Some 2500/3500 HDs don’t have it.
/ 2014 3500HD button on dash. What does it do? #3
Looks like it is probably an optional pto control.
/ 2014 3500HD button on dash. What does it do? #4
Exahust brake?
/ 2014 3500HD button on dash. What does it do? #5
Whatever it is , it's in an awkward place for the driver to access.
/ 2014 3500HD button on dash. What does it do? #7
Looks like that is what it is, mystery solved.
Thanks, I looked for about 10 minutes and couldn’t find what it was.
Makes sense as it was on a 3500 cab/chassis with a dumping flatbed.
Pickups mostly have a cubby hole.
/ 2014 3500HD button on dash. What does it do? #9
I know what a PTO is but since I didn't know what it imply exactly here it is...
How It Works​
2020 GM HD trucks will utilize a PTO that’s drive gear operated via a chain to direct engine power. Since PTO on the trucks is engine-driven rather than turbine-driven, owners can use the PTO while the vehicle is idling. A button inside the cab enables the PTO, and a mode selector allows adjustment of load and torque output.
The General says that the 2020 GM HD trucks will be the first in the HD truck segment to feature a fully integrated PTO system.
Most are on the side of the Allison transmission.
/ 2014 3500HD button on dash. What does it do? #11
I don't know about 2020 GM's being the first to have PTO's off the transmission (if I read that right). My 2011 F250 has the Allison trans that is pto capable, but was only offered as an option by Ford on the F350.
I always though it would be cool to power a big generator head off the truck.
/ 2014 3500HD button on dash. What does it do? #12
within GMC in the HD class what ever that means, it was past from the GMC website... but op truck in question is a 2014 and it has it but it's a 350 ... I simply wanted to know the functionality of the PTO. here is the link I pasted it from.
Doesn’t your truck have a Torqshift transmission?
My IH-7500 has an Allison Rugged Duty Series and the PTO is on the side of the transmission.
My Ram 5500 has a PTO which I can turn on/off via a switch on the dash, but I don’t have a dump bed (would love to have a PTO air compressor, but BIG $)
/ 2014 3500HD button on dash. What does it do? #16
I checked my specs, you are correct. Not sure where I got Allison from, but that has been my belief for the past 10 years!
