2013 Kioti RC6010 curl function doesn't work
/ 2013 Kioti RC6010 curl function doesn't work #1
jcowling
Iseki TS1910
I have a co-worker that ows a 2013 Kioti RC 6010, 59 Horsepower tractor. I was using it and the curl function on the stick seemed to just lose pressure and function. Even with the tractor off, when I push it to the left, it feels like there is nothing there. No resistance and won't come back to position. Does anyone know what to check, also is there a diagram on this so I can see how it works. He says it has a valve, that has two cables down to a spool valve.
Thanks for the info.
/ 2013 Kioti RC6010 curl function doesn't work #2
If two cables from joystick to valve you need to look at end of joystick to confirm cable is still connected properly and then look at valve end to confirm moving on that end also.
Thank you. I'll have him check that, and then come back here. Thanks again
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2014 BOBCAT E42 EXCAVATOR (A64279)
2014 BOBCAT E42...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A61572)
2025 Wolverine...
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A61572)
2023 John Deere...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
