2013 Kioti RC6010 curl function doesn't work
/ 2013 Kioti RC6010 curl function doesn't work #1
jcowling
Iseki TS1910
I have a co-worker that ows a 2013 Kioti RC 6010, 59 Horsepower tractor. I was using it and the curl function on the stick seemed to just lose pressure and function. Even with the tractor off, when I push it to the left, it feels like there is nothing there. No resistance and won't come back to position. Does anyone know what to check, also is there a diagram on this so I can see how it works. He says it has a valve, that has two cables down to a spool valve.
Thanks for the info.
/ 2013 Kioti RC6010 curl function doesn't work #2
If two cables from joystick to valve you need to look at end of joystick to confirm cable is still connected properly and then look at valve end to confirm moving on that end also.
Thank you. I'll have him check that, and then come back here. Thanks again
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
2017 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2017 DRAGON 150...
832781 (A61166)
832781 (A61166)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
