2013 JD 3032E questions
/ 2013 JD 3032E questions #1
Emptypocketfarms
Looking to buy
Can you guys tell me some info about this model? A quick google search doesn’t reveal any GLARING issues, but thought i would ask the experts….
thanks in advance……
/ 2013 JD 3032E questions #2
I think, in general, there are going to be good and some bad tractors within each model series for any manufacturer. Sometimes it depends on the dealer.
most reviews on the internet will be inherently negative because people usually post when things go wrong vs when everything is working fine.
if the 2013 you found seems to be in good condition (it's been working fine for nine years presumably), then I would consider that to be a positive. Also depends on the prior owner - was it a single residential owner, or a rental yard? Big difference.
/ 2013 JD 3032E questions #3
I don't own a 3 series but i think they have an aluminum rear trans housing. I think it's the only madel like that but I'm just going by what I read on a JD forum.
/ 2013 JD 3032E questions #4
thanks in advance……
what kind of info? We have a 3032 and they are a decent small tractor. With loaded rear tires it will lift a 4x4 hay bale but a 4x5 needs a counterweight too. Use it for a variety of load and carry tasks around the farm. We have bigger stuff to do the plowing, mowing. baling type jobs.
Busted a headlight and the replacement comes with a different bulb so the wiring has to be field adapted,
