Buying Advice 2013 5065e or 5075e
/ 2013 5065e or 5075e #1
Jmarnott
Murfreesboro, tn
None yet
Stopped off at the local jd dealer today.. To get some quotes for the 2013 5065e and 5075e with the power reverse. I am trying to keep my purchase no more than 35k.. It is looking like I will have to go with 65e in order to make the deal as the 75 was about 2500 over my budget. First question do you think I will really notice the 10hp? Is the frontier rc2084 cutter worth the 3200.00 price tag? Anyone else have any price quotes they can share for the 2013 5065 or 5075e with fel?
/ 2013 5065e or 5075e #2
Not sure on the tractor itself, but I'd avoid getting the RC2084 (or any single spindle 7' cutter). It will be very long and cumbersome and take more power than you'd imagine. For that price you could get an MX6, or spend a bit more and get a MX8. Generally an 8' dual spindle takes less power to run than a 7' single spindle cutter.
/ 2013 5065e or 5075e #3
Can't help you with the 5065E, but I just got a quote on a 2013 5055E with 553 loader , hood guard, 16.9-28 tires and all the valves and what not and Power Reverser and after the discount for the power reverser it was just under $30,000 delivered to my place and I that was the first written offer, haven't haggled on that yet.
Dan
It seems that from what I read, some people just buy the smaller tractor in the series and hop them up later to get the extra hp. That would for sure give me enough room to get the mx8 if I got the 5055e
I was looking at about 32000 for the 65 with fel, tires filled, hood guard.
/ 2013 5065e or 5075e #6
I assume you guys are talking about non cab versions right? How much extra does the cab version cost? Also, if you get the power reverser, the EPTO option comes with it right?
I have been trying to find some sort of comparison between the 5075E with cab, and the New Holland T4.75 with cab but they are both still so new that there isn't much info on them.
Is the Deere Tier 4 yet? The NH is still teir 3.
Yes, this is the open station. I think I read that the cab add a good 7-9k on another thread. I know the M series with the power reverser has the epto. But I am not sure if the e series will have it. I will ask the dealer today. I do agree information is light on the new model.
Actually I just looked on the jd site it looks like the power reverser does have to epto/standard.
Well went back today to do a final check on time frame in which the 2013 will start to be available to be ordered. THEY TOLD ME APRIL.!!! Wth. How is JD going to compete with having power reverser in April when other brands offer it now.. I did have him run the quote for a 2012 5075e w/fel and I was about 33k.. Any other quotes on the 2012 5075e
/ 2013 5065e or 5075e #11
As far as I know the power reverser trans is only available on the cab models. The 5045e-5075e open station are just like the previous ones, but tier 4. Based on what the dealer told me, all they have done to make those particular models tier 4 is fiddle with the timing and fuel delivery, and bump the price up (they are also harder to start when cold). I was looking at 2013 5045d's and decided to go used instead. It's amazing how much easier my 5203 starts vs my fathers 5045e (2011 model, tier 3).
The power reverser will be available on the open cab models as well as my dealer was able to build the quote, just won't be shipping until around April. The other option I have is a 2007 5425 power reverser with 100 hours for 30,500. I am just A little worried that it has been sitting for to long with out any use..
/ 2013 5065e or 5075e #14
Good to know the new 5000E's will have the power reverser option.
Btw, I know the fuel delivery is the main difference between the different HP, but does anyone know exactly how to adjust it?
/ 2013 5065e or 5075e #15
Although BuickandDeere makes it sound easy, from what I've read on here about the 4x20 series is that it's virtually impossible to economically boost the power to more hp.
There is a lot more to it than turning a set screw. If you need/want more power, spend the money up front and be done with it. Not to mention, you'd be voiding the warranty on your brand new tractor, plus, who's to say you wouldn't mess anything up in the attempt to upgrade the power, then it ends up costing you more than if you just bought the tractor you should have bought in the first place. :thumbsup:
Well... I told the dealer to get a 2012 5075e setup for me with 553 gel and the mx8 cutter... While it would have been nice to be able to get the 5045e.. I found no detailed info on what is involved to make a 45 in to a 75, while I do understand that some of it involves fuel flow, I would be surprise if that is the only change. Seems like there would need to be some turbo tuning, and some timing changes.
/ 2013 5065e or 5075e #17
Good choice! Yeah, I'm quite certain that there is a *lot* more to it than just turning some "set" screw...
Now, if they came out with something list "LS1 Edit" like they have for the Chevy small blocks, where you can edit the fuel delivery curve, timing, etc, then we might be talking! Or something like the Predator for the Chevy Duramax engines where you can do the same thing by selecting from 4 different power levels, then we might be in business, but I just don't think the market is big enough for a 3rd party to get into that game. In some ways, diesel engines are easier to tune for more power than gas engines since you don't have to maintain a certain air to fuel ratio and can simply increase the amount of fuel delivered for more power, but you have to watch exhaust temps and turbos adds a whole other dimension to things that can go wrong when too much fuel is being delivered!
I run the predator on my 2002 Duramax truck, and I can tune it to where the Allison transmission start to slip and goes into limp mode. You are playing with fire for sure however.
That said, it would be cool to be able to program your factory fresh tractor for power that that crazy Swede that put a turbo on his tractor and can go 60 mph down the road and make rooster tails in the field at will. :)
/ 2013 5065e or 5075e #18
The open station 5e series are still all mechanical injection, no electronics whatsoever. In theory it is possible to take a 5045e and 'turn it up' to a 5075e. With that said, I'm not sure the practicality of it as the EPA has done everything the can to make sure you can't fiddle with the injection pump. I would hope there is still some adjustment in the pump, but it wouldn't surprise me if more fuel = buying a different pump. Also, there are other changes that go along with, or are used in lieu of turning up the fuel. I think to go from the 5045e to 5055e it is just a change in timing, then to go to the 5065e its a change in fuel delivery. Not sure what the 5065e vs 5075e change is, but it might involve the boost pressure, etc. Sometime I hope to get a shop manual for these tractors and see if I can figure out what the real difference is. Regardless, buying the right size from the start is sound advice, and I wouldn't go tinkering on a brand new tractor anyways.
The 5075e and MX8 will be a nice combo.
/ 2013 5065e or 5075e #19
The injector tips size does change along with pump elements.
Electronic common rail systems are easy. Just install higher flow injectors to use with the stock timing.
/ 2013 5065e or 5075e #20
No such thing as a "Free Lunch"! Horsepower or cheeseburgers... you get what you pay for! Much discussion here (and other brand forums) on the 4000 series (and some on the cab model 5083e) of jumping the horsepower with a little "tweak" on the injector pump.
A detailed review of the parts listing's (pump, turbo, injectors) for the different Hp rating on the 4000 quickly illustrates that it's not JUST a set-screw on the pump. It's a whole lot more!
'Course, I don't know about you - but, if I'm gonna buy a NEW tractor - why, why would I trash the warranty right off the dealer's lot??!?
Pony up for those extra horses.
AKfish
2004 CASE CX75SR EXCAVATOR (A65056)
2004 CASE CX75SR...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2006 Ford F-750 Terex Commander C4047 Digger Derrick Truck (A68183)
2006 Ford F-750...
2014 FORD F-150 (A67714)
2014 FORD F-150...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
