2011 Superduty are out! ! !
/ 2011 Superduty are out! ! ! #161
Drove a 2011 F250 with 6.2 gas, auto, 3.31:1 rear...comparing it to my F350 V10, auto, 4.30:1 rear (everyday drivability, not towing)...good ride, plenty of low end torque, good road manners, but the 6 speed auto tended to "hunt" at lower RPM's, found that annoying but will attribute it to the high gearing...may do better with a lower ratio. Not quite as torquey as my V10 so as of right now I'd say it doesn't pass the test. I did notice the missing 45 cu. in. No replacement for displacement. Felt like my friend's Hemi Dodge (which I don't like).
IMHO, that 6.2, V-8, 6 speed, will never satisfactorily replace the V-10. Thankfully, I'm no longer a Ford groupie, but that move doesn't make any sense to me, except Ford forcing buyers to purchase their diesel :thumbsup:
/ 2011 Superduty are out! ! ! #162
...and at one heckuva premium, at that. I'm not a big diesel fan for "joe blow" everyday use...contractors, daily towing and fleet use is where they belong, IMO. I like my gas engines, but I also tend to like large displacement engines...the 415 cu. in. V10 is one of the smallest gas engines I own (460's, 428's, 429 and one 390, all Ford). Even my rollback has a gas 460, although I'll admit, if it weren't for the split diff. I would probably have a diesel in that truck.
/ 2011 Superduty are out! ! ! #163
Ya, tough to beat "big blocks", but the fuel penalty is significant now, cost wise. I tow a couple trailers, the heaviest weighing 8,000/8,500 lbs loaded, with a 5.7L Tundra with 4:30 gears, 6 speed auto. The truck has no problems towing the trailer, but fuel mileage is around 9 to 9.5 MPG. The saving grace, is empty mileage, which is most of my mileage, better than 18 MPG. A friend has a F350, 6.8 with 4:30,s and an older F350, 460 with 4:56 gears; guess which truck he prefers? the 460
/ 2011 Superduty are out! ! ! #164
That was a very big gear ratio difference. I wonder how one with a similar ratio would compare to your V10.
The new 6 speed that the 2011 come with are geared lower in the first 4 gears so you can use taller rear gears. the 5 and 6th gear are both over drive gears, this allows for better hwy millage.
/ 2011 Superduty are out! ! ! #166
I don't think the final drive ratio is the problem as I observed it...more like the individual transmission gearing...seemed it couldn't make up it's mind between 2-3 and 3-4 most times...I did try it on a hilly section of highway as well and the biggest "hunt" seemed to take place between 3-4. I think it's time the manufacturers looked at something like the Gearvendor's type of overdrive system...also, if you are going to build a truck capable of towing the kind of weights we're dealing with, I'm ready for a manual with a split rear for my needs...probably wouldn't be a real popular option but I'd sure take one. But, I was raised on big blocks with manuals and I do miss being able to downshift for engine braking (although I catch myself doing it with the auto). I guess I'm just getting old.
/ 2011 Superduty are out! ! ! #167
I'm sure that would be a really big seller - given that the manual transmission made up less than 1% of Superduty sales last year.
If you were aggravated by it "hunting" then you should have driven the truck in the manual mode where you do the shifting. You could also program out one of the gears so it went from 2nd to 4th as an example.
/ 2011 Superduty are out! ! ! #168
I need to manually shift the automatic transmission on a $62K heavy duty truck??? On an open highway under no load? This ain't my first rodeo. Again, this was just a basic road test on a $62,000 vehicle and you honestly are telling me that I shouldn't be able to turn the key and drive away...I need to manually shift this electronically controlled high tech 6 speed transmission? This wasn't towing or some special test session...just regular everyday driving. I love my Fords, but this combo leaves me wanting. And yes, I acknowledged a manual with a split rear wouldn't be a popular combo (read post thoroughly, please) but if I am going to have to manually shift an automatic trans to keep it in the proper torque band for everyday driving, I (maybe not you) would prefer a true manual transmission.
/ 2011 Superduty are out! ! ! #169
This reminds of the old saying/joke in the computer software business, "That's not a bug, that's a feature." Talk about turning a vice into a virtue. :laughing:
/ 2011 Superduty are out! ! ! #170
I may have missed it here or something. Help me understand something-Are all manufacturers getting away from manual shift transmissions? Can you special order them?:confused:
sad to say but you can't get a manual in the new super duty, not even on the XL line. I don't know for sure about the other two players but i think Chevy did away with them a long time ago, and i think you can still get one with dodge. . . but not sure.
/ 2011 Superduty are out! ! ! #173
No manual for Ford or GM. Dodge still has one but I bet its on the way out also. If you have not driven a late model truck, say 2004 or newer with a Ford Torque Shift or a GM Allison they are terrific. The Dodge tranny left a lot to be desired upto about 2008 or so when they got the Asian or whatever its called and I hear its a winner also.
Chris
/ 2011 Superduty are out! ! ! #174
Actually the 5 speed 54RFE tranny that has been in the RAM since 2003 has proven itself to be very reliable. Mostly unchanged since 2003 also.
I bet Dodge will never get rid of the manual shift tranny, it's obviously selling. The difference is Dodge builds the trucks people want and not what the bean counters tell them to. :cool:
The 2011 RAM's still have a 6-speed manual option.
and that is why ford has been the #1 selling truck for what a bizillion years:D
Sorry Dmace but i couldn't help my self after reading that comment
No. 1: Ford F-Series
413,625 -19.8% YTD
December 2009: 48,209
December 2008: 41,580
No. 2: Chevrolet Silverado
316,544 -31.9% YTD
December 2009: 33,301
December 2008: 33,340
No. 3: Dodge Ram
177,268 -28.0% YTD
December 2009: 12,014
December 2008: 16,618
These were 2009 numbers, guess we'll have to wait to see what 2010 has to offer
/ 2011 Superduty are out! ! ! #176
Well my Ram Hemi 2500 had 2 trannys in it before 60K. So that leaves a lot to be desired in my opinion. I know tons of others who have also had Dodge truck Auto Trannys with issues like our work Dakota. I have owned 20 plus vehicles and these are the only 2 tranny issues I have had along with a transfer case in a Blazer.
Chris
/ 2011 Superduty are out! ! ! #177
Like I said, that's what happens when the bean counters tell you which truck to make instead of the consumers. You sell more but in the end, the consumer buys what the company wants and not what they want. It's funny how many people think sales numbers have anything to do with how good something is.
The Mustang outsells the Porsche Carrera quite a bit too but I would take the Porsche any day. :laughing:
Anyone that can kill a tranny twice in 60k can not blame the truck these days, it's obviously the "nut behind the wheel". :D
98k miles on my 03 with the 54RFE auto tranny and it hasn't given me any problems. More than half those miles are towing and we have hills up here, no flat land for miles...
/ 2011 Superduty are out! ! ! #178
Sorry to lob this in there, but I feel compelled. Ford is the only one of the (formerly) big three not owned by the government and the unions.
God bless America
resume your argument:)
/ 2011 Superduty are out! ! ! #179
Funny how I have never had as much as a hiccup out of the nearly dozen Fords or the Honda, Nissan, Toyota, even GM.
Comparing the $30,000 Mustang to a Porsche that cost nearly three times as much just shows you how bright you are.:D Its like comparing a 1/2 ton truck to a Semi.
Real sharp!
Chris
/ 2011 Superduty are out! ! ! #180
Soo...the consumer buys what the company wants ...and not what they want?? Year after year??
Comparing porsche sales to mustang sales??
Blaming 2 failed transmissions on the operator??
Here's the real question.... Is it dimensia, lunacy, or does he just enjoy infecting these threads like a bad computer virus.....
