2011 Cub Cadet Tank L60
   / 2011 Cub Cadet Tank L60 #1
InniMan
Granville, Ohio
Cub Cadet 2550
My dealer has a few of last years model(2011) at a discounted price. I was in the market for a new tractor for mowing about 2.5 acres but, Cub hadn't crossed my mind. The price is so good I'm taking it under serious consideration. Anyone out there own a 2011 Tank? Is it a reliable machine? Does it have trouble in wet grass? Please share what you know . Thanks!
   / 2011 Cub Cadet Tank L60 #2
Don't own an 11, but own a 2007 M72 tank with the diesel. From my limited experience with it, it is a mowing stallion.:laughing::thumbsup: You can mow very fast and really cut down mowing time.
Very reliable and built like a ....well.....tank. :laughing:
Not the best on the slopes I have though, and it's spent most of the time in the garage. I bought it for a house we WERE going to build which will have a huge lawn, not that build is in question....actually doubtful at least for a few more years.
For wet grass, it's OK but will tear up the grass a bit if you do a 180 spin on a dime. Just have to exercise a little caution.
I'll probably be selling my M72 this spring......hate to, but not using it enough. I'll probably need it right after I sell it..... :(
   / 2011 Cub Cadet Tank L60 #4
If memory serves me correct, the L series has a few less features than the M series tanks but still runs the same hydro pumps and motors... which is a good thing. For your situation it should serve you well, plus you can always add a suspension seat later if needed.
   / 2011 Cub Cadet Tank L60 #6
That's a nice heavy-duty zero turn. Separate pump & wheel motor drive. Heavy deck & hanger hardware etc. At ~1100lbs, traction shouldn't be too big a problem, but like anything, you have to take it easier on wet grass to avoid a mess.
I owned a Z-Force 44" fab for two seasons and enjoyed it, but found my Cub 2544 to be more comfortable for the conditions I had at the time; Hilly and bumpy.
The Tank is bigger, wider, heavier and has much more allowable up/down movement of the deck, so it's a better machine than a Z-Force.
ServeImage.aspx
Joel
2016 Textron T/A 15 Ton Flatbed Equipment Trailer (A59230)
2016 Textron T/A...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
