2010 MF1532
   / 2010 MF1532 #1
tmiller62
Massey Ferguson 1532
recently purchased 2010 MF1532. Having issues with Dif lock and four wheel drive. I can't engauge the dif lock and four wheel drive works great in low gear but the tractor stalls when in high and four wheel drive. anyone have any ideas?
   / 2010 MF1532 #2
If it's anything like my gc1710 the diff lock doesn't engage until the wheels start slipping. I step on the diff lock pedal and keep gentle pressure there and once my traction gives way in it goes like butter.
   / 2010 MF1532 #3
gc1710 is correct. The diff lock will only engage once the rear wheels start to slip. It will automatically disengage once the load is relieved. When I'm in a tough spot I engage the diff as needed. As for the stalling, I would check your fuel filter. I've had my filter clog up pretty quick mostly because my fuel transfer tank had some junk in it. regardless I've experienced loss of power. The fuel filter is easy to swap and is readily available just about any auto parts dealer. Here are some part numbers for you; WIX 33262, Purolator F60053, & NAPA 3262. Good luck.
   / 2010 MF1532 #4
HST, syncorshuttle or powershuttle? Have you checked the oil level in the front axle?
   / 2010 MF1532 #5
This is excellent information.
Might I add a little bit:
Drain out your fuel and Shop-Vac your tank out to be sure all the trash is out.
There is a spill collar around the filler. If you don't regularly clean the drain tube, cut this collar off and throw it away. It will fill up and introduce water through the vent in you fuel cap.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
