2010 DK45 PTO solonoid
/ 2010 DK45 PTO solonoid #1
SouthernSooner
Tecumseh, ok
Kioti DK45 HSE
I have had intermittent PTO engagement. I see the valve body on right hand side that has two solenoids. One on the front side and one to the back. I checked for 12v on the back connector and didn’t have any with switch on or off. All wires (as far as I could see) looked in tacked.
- is the solenoid facing the rear, the PTO side?
- any ideas on the wiring where the break could be?
- debating shotgun troubleshooting and just replacing the solenoid. Is it cut and dry?
/ 2010 DK45 PTO solonoid #2
I had a problem this summer with my Dk40SE where the PTO would engage sometimes, not others. The relay the operates that solenoid is behind the dash and you have to pull the entire cover off to get access to in.
I cleaned up the ground initially, but it didn't solve the problem, in the end, I replaced the relay and everything has been working fine since then.
There are two part numbers, my tractor has one version, the dealer had the other version in stock and it worked fine.
T4935-43101
TWIN RELAY, MOTOR
T4935-43102
TWIN RELAY, MOTOR
Jason
/ 2010 DK45 PTO solonoid #3
I replaced the relay on mine 2 years ago. Its a standard double relay that kioti uses. Its behing the shroud on the sreering column like was said above. Easy to replace.
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
Four (4) John Deere 8R Front Fenders (A65640)
Four (4) John...
2013 FORD F-350 SUPER DUTY (A65643)
2013 FORD F-350...
Trenching Excavator Bucket (A65640)
Trenching...
(5) John Deere Front Tractor Weights (A65640)
(5) John Deere...
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 HINO 195 18FT...
