2006 L3940 Seat issue
/ 2006 L3940 Seat issue #1
okiecraig
Creek County, OKlahoma
1972 MF 135 diesel, Kubota L3940
Need Forum help once again. :) The seat back has lost the ability to remain fixed where placed by the adjustment handle on the left hinge (see photo). I need to remove the hinge cover to investigate. I removed the small black bolt that appeared to attach the adjustment handle to the seat. However, I cannot get the cover off! The adjustment handle seems to still be under tension even with the bolt removed.
Any suggestions?
/ 2006 L3940 Seat issue #2
It might be glued on there or else there is a special release tab.
Solved this one. Used adjustable pliers to gently grab seat handle and pull straight out. Then cover was easy as only held by 3 tabs. The bolt that came out of my seat fell out of the cover when removed, reinstalled, problem solved. LOL. Thnaks for all views and comments......:)
